Go Back   AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 > Q5/SQ5 Discussion
Q5/SQ5 Discussion Discussion forum for the Audi Q5 SUV
Sponsored by: Audi
Old 02-12-2014, 12:46 PM   #1
MP4.2+6.0
Senior Member
Account #: 26081
Default 2014 Nav tweaks? Can someone w/ 2014 Nav give me your HW and SW rev levels...
Can someone w/ a recently delivered 2014 w/ Nav give me your hardware and software rev levels per the Version screen?
As a follow up to my unfortunate electronics replacement trifecta over recent months, I'm noticing some small things seem different and updated in Nav. with the replaced unit that went in earlier this week. (Prior post was here: http://forums.audiworld.com/showthread.php?p=24539327). Maybe it's a consolation prize where I find some "lemonade" from the three lemon electronics modules to date.
When navigating to a destination, the route summary on the left side is now showing icons for the preselected favorites categories (gas, restaurants, etc.) at upcoming exits on freeways. Before it just showed future turns and never with any icons. The icons were only on the map itself. It makes that feature more useful, whereas before the route turn in 30 miles stuff just seemed like unnecessary screen clutter I was getting about ready to turn off. When routing to a destination, it also now switches the MMI display right before a turn in that same left screen area with a large directional box with a big arrow that makes the turn much more obvious. Neither my wife nor I recall these on the 2013 Nav version it started with, though it's possible the differences are in some subtle user set up choice. My prior Toyota (and Smart) with the underlying Fujitsu Ten system was set up more like this with the upcoming turn display, while previously on the Audi that kind of guidance was more something I looked at the center display for.
Both of these could just be a setting that's a bit different now since the whole thing went back to the default settings when the Nav unit got replaced, but I'm wondering if along the way it got the latest Nav related software load, and also whether it got the current Nav maps load since that is no longer a separate DVD. I know from a post I saw in the fall, my very late 2013 build still started with versions that were older than early 2014's.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here.
Current #2: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery 7/2013 (pictured at Ingolstadt)
Prior (each modded): 2000 C5 A6 4.2 & '96 C4 A6 2.8Q, both still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS
helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
MP4.2+6.0 is offline   Reply With Quote
Old 02-12-2014, 05:39 PM   #2
fsufan6000
Account #: 244362
I have a 2014 w/ NAV built in October of last year and I have the icons as you describe. Sounds like some lemonade. Where should I look for the rev levels?
fsufan6000 is offline   Reply With Quote
Old 02-12-2014, 06:33 PM   #3
Waldorf
Account #: 275540
I just got a 2014 3 weeks ago and the nav cues are the same as you describe. I actually thought they have to do with Audi connect and google as I don't get the icons in the summary when I am in an area that is not serviced by T-Mobile 3G (which is 75% of my driving territory, unfortunately...). The switch to the directional box also happens and can be set in the driver view as well....
Waldorf is offline   Reply With Quote
Old 02-12-2014, 06:45 PM   #4
81Coupe
Account #: 252991
If we are talking about the same feature: the MMI showing along the way, for instance, every exit that gas and food are available, etc. That feature is already present in my 2013 Q5 (built in March/April, delivered early May). It can be turned off in the Nav settings, if I remember correctly.
Once and again Audi owner
1981 Audi Coupé
2013 Q5 2.0T P+ Nav, Adv. key, Rear airbags
81Coupe is offline   Reply With Quote
Old 02-12-2014, 08:20 PM   #5
Reggie
AudiWorld Expert
Account #: 102
Reggie's Avatar
Exactly - it's a case of RTFM
Reggie is offline   Reply With Quote
Old 02-12-2014, 09:15 PM   #6
spijun
Account #: 184703
spijun's Avatar
U.S. maps exist versions:
With each new version maps comes a new version of software for this map
Version 8R0-051-884BL will be available from April
Example:
For the new version map EU2014 - 27GB size , there are two CD for software upgrade. Maps come on 32GB SD Card
To upgrade the software required is 35-40 minutes, and upgrade maps 2 hours 30 minutes
Q5 2.0 TFSI,S-tronic,
Milano leather, B&O, 19" 5-arm polished
Excuse me for my English
spijun is offline   Reply With Quote
Old 02-13-2014, 06:26 AM   #7
Jubz
Account #: 256473
Jubz's Avatar
...snip
Picked up my 2014 Q5 TDI, Prestige/Sline+, in November 2013; info I pulled out of my MMI for you.
MMI Software Version:
HN+_US_AU3G_P0715
Navigation Database Version:
8R0060884BD NAR 6.8.2
And yes, my nav screen shows the various icons and route info on the left side of the screen, along with zooming in with upcoming turns. The icons/route info on the left side of the screen can be adjusted via the setting: Navigation|Route info; where you have the options of: On, Route, Exit, Off.
Hope this helps.
Jubz is offline   Reply With Quote
Old 02-13-2014, 06:48 AM   #8
snagitseven
Account #: 22753
snagitseven's Avatar
I believe the MMI software is responsible for the additional info features on the screen as previously described. The Nav software versions would just update the base map and internal POIs. I'm not certain but I seem to remember the POI icons were present on my MMI 0566 if selected as an option in the MMI settings but in any case, definitely on 0715-2.
- 2013 A6 3.0T Prestige, Quartz Gray/Black, 19" Sport, Driver Assist, LED headlights,Cold Weather and B&O;
Bridgestone RE970AS tires; XPel Ultimate full front, mirrors and rocker panels, Opti-coat Pro
- 2002 allroad 2.7t - 13y/49K mi and still like new
- 2009 A4 3.2 Prestige w/Nav (sold at 4y/48K mi)
- 2001 A6 2.7t (sold at 8y/98K mi)
snagitseven is offline   Reply With Quote
Old 02-13-2014, 08:07 AM   #9
MP4.2+6.0
Senior Member
Account #: 26081
Default Thanks, FWIW, my full part # is yet different
Per a scan, the maps version in the car now is for "NAR 2013" (presumably acronym is North American Region) and ends with the two letter code BA; the earlier numerical part matches the #'s you pulled.
Old 02-13-2014, 08:28 AM   #10
MP4.2+6.0
Senior Member
Account #: 26081
Default Follow up--any change is apparently yet more buried apparently.
So, I checked my map version, and it is (still) at NAR 5.7.3. Software is (still) at HN+_US_AU3G_P0809. But wait...
Next I pulled a new full scan. I had a prior scan from electronic preceding issues I could compare it against that also included the then functioning prior module. Each and every hardware, software, component and subsystem number is identical, so no apparent change. The long coding for the module remains identical too (and you're saying, so what...). The shop # has changed, as I would expect from the dealer service assigned number, and the "VCID," which I'm guessing might be where component protection is (??).
Well, meanwhile at the bottom of the scan for the module is says:
1 Fault Found:
03276 Please Check Software Version Management
000--
So, the numbers and versions actually basically all line up pre and post Nav unit swap out, yet the component or vehicle is generating an error post change out that says there is a supposed software version mismatch. I'm not currently concerned since the vehicle and Nav function fine currently. I can just have them review any codes the next time I'm in...hopefully not until 15K. I did find an adaptations post about this, but figure just let the dealer deal with it later. Also unclear to me as an adaptation how/whether it affects any part of what the user sees: http://www.audienthusiasts.com/Appli..._SVMError.html
Forum Jump
