Old 02-12-2014, 10:24 AM   #1
Jfthrasher
Account #: 277001
Default Mmi issues
A8l 2004. The mmi screen and radio would go on and off randomly. Removed center console and opened up controls and cleaned curcuit board and found stuck button. Cleaned and put back together and everything worked great except car button. Removed again and cleaned that area on curcuit board and reinstalled now I have nothing seams all power is gone. Any thoughts would be appriciated.
Thanks
Jamie
Jfthrasher is offline   Reply With Quote
Old 02-12-2014, 12:21 PM   #2
MP4.2+6.0
Senior Member
Account #: 26081
Default The circuit board does not like liquids.
If you did it with just air, an electronics solvent or rubbing alcohol that dried, it should be okay, and I would recheck connections and then wherever the fuse is. If you used a water based or non quick dry solvent (409, Windex, whatever) unfortunately you may have fried it with power applied.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here.
Current #2: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery 7/2013 (pictured at Ingolstadt)
Prior (each modded): 2000 C5 A6 4.2 & '96 C4 A6 2.8Q, both still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS
helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
MP4.2+6.0 is offline   Reply With Quote
Old 02-12-2014, 12:57 PM   #3
Jfthrasher
Account #: 277001
I used an electronics quick dry plastic safe solvent. I couldn't locate a fuse for tuner. I did find the fuse for the nav system and it was fine. Still get no lights sound land screen does not open.
Old 02-12-2014, 01:58 PM   #4
mishar
Account #: 195381
mishar's Avatar
Screen won't open if it is muted. Try pressing the volume button.
mishar is offline   Reply With Quote
Old 02-13-2014, 11:41 AM   #5
Jfthrasher
Account #: 277001
I have pushed all buttons. And still nothing Even tried the three button reset and system does nothing.
Went ahead and orderd replacement control .. We will see if that does it.
Old 02-18-2014, 09:11 AM   #6
Jfthrasher
Account #: 277001
Replaced control buttons in center console and still nothing.
Checked fuses on both sides of dash and on both compartments in truck. All look good
Any suggestions?
Old 02-18-2014, 09:57 AM   #7
mishar
Account #: 195381
mishar's Avatar
Have you replaced only buttons or circuit board too?
VCDS scan would be the next.
Old 02-18-2014, 10:10 AM   #8
Jfthrasher
Account #: 277001
Complete new assembly buttons and circuit board
Old 02-18-2014, 06:50 PM   #9
Jfthrasher
Account #: 277001
Having scan done tomorrow
Old 02-20-2014, 02:12 PM   #10
Jfthrasher
Account #: 277001
Spoke with mechanic and he said he had never seen such.... The scanner makes no connection to mmi units. He said it was like they were not there. We are all scratching our heads.
Forum Jump
