B7 3.0 TDI Quattro Automatic Problem
Hello everyone,
As stated in the title I've a problem with the automatic box on an A4. VCDS is showing codes referring to problems with the TCM/TCU.
Does anyone know where the module is located? Autodata's indicating that it's beside the ECU under the scuttle panel. Removed it all and can't seem to see it. Also checked under both carpets as I've recently replaced a damaged TCM on a Automatic Passat and it was located under drivers foot.
Any advice would be very much appreciated
