Backup Sensor Sound
Old 02-07-2014, 02:07 PM
R3Wood's Avatar
Default Backup Sensor Sound
Yesterday, backup sensor speaker/sound was fine, pulled in garage.
Today I backed up, the sound on the backup sensor was muffled, low and the tone was off.
It still works, but the sound is way off?
Any ideas? I searched the forums but came up with nothing.
Old 02-07-2014, 04:31 PM
ericA6's Avatar
Unfortunately the horn went out on you. Not the easiest part to replace. Lots of panels to remove. Cheap at the dealership though.
Old 02-08-2014, 05:12 AM
KevinGary's Avatar
Pretty common problem on our cars. The horn went bad. It is pretty cheap at the dealer. You can also try changing the tone through MMI and see if there is a better sounding tone
Old 02-17-2014, 07:14 AM
R3Wood's Avatar
Thanks for the replies. I will get this fixed when the weather breaks.
Old 05-14-2014, 07:48 AM
R3Wood's Avatar
Default C-Pillar
Are there any clear cut instructions on removing this C-Pillar to get to the backup horn? This installation sounds like the dealer could screw this up big time?
Old 05-15-2014, 11:42 AM
dudeZi's Avatar
it is pia to remove all the trims to do it right, there is a short cutwhen u fold your driver side rear seat, you can reach the speaker plug, which is behind the seat belt housing, just unplug it, and plug it to the new speaker, then hide the new speaker somewhere under the rear dashboard.
Old 05-16-2014, 04:58 AM
R3Wood's Avatar
Thanks!
Old 05-19-2014, 03:30 AM
R3Wood's Avatar
I searched for it, but could not find it. Do you need to loosen the trunk trim where the seat meets the trunk? Mine is a 2005 A6.
Keyser Wi
Q7 MKII Discussion
11
04-24-2017 06:31 PM
Leppee
Audi allroad
02-25-2014 11:01 AM
Simkin
11-26-2008 04:01 AM
audix
05-03-2008 10:45 AM
Quick Reply: Backup Sensor Sound
