rear door curtians
Old 02-04-2014, 02:07 PM
dcbadb's Avatar
Default rear door curtians
Can anyone tell me how to remove and reinstall the rear door curtains in a 2012 a8 L. Thanks
Old 02-04-2014, 08:51 PM
jakematic's Avatar
See parts diagram here: http://www.audiusaparts.com/parts/20...iagram=1362855
Remove trim molding pieces
Remove 3 bolts
Release 2 part clip near entry lamp - part #3
Release 8 door clips
Release control cable and electrical connections
Remove door trim panel - #1
Turn push rod (#29) 90 degrees about axis and detach from blind (#26)
Turn push rod 90 degrees to detach from motor
Remove 3 bolts along bottom of blind assembly
The procedure pages in the erWin manual are quite lengthy and my guesstimate would be at least 2 hours to disassemble.
I would absolutely have extra door panel clips on hand before you start, a T10383, and a good set of trim tools.
Last edited by jakematic; 02-04-2014 at 10:24 PM. Reason: erWin link corrected to NAR
Colin Penman
10-29-2015 01:02 PM
The_Hamster
Audi 100 / A6 (C4 Platform)
05-15-2007 08:37 PM
alvas
09-09-2004 08:05 AM
bittersweetno1
07-17-2003 04:23 PM
machoquattro
03-24-2002 06:03 AM
Quick Reply: rear door curtians
