2006 MMI Help....Please
Old 02-03-2014, 03:39 PM
ESICA14's Avatar
Default 2006 MMI Help....Please
Greetings...
Well the wheels are coming off the cart soon after my extended warranty expired. I'm trying to fix what I can and off to the dealer for the rest.
The latest big problem is my MMI and all associated buttons, bluetooth and lights are not working. The screen is in the up position and off.
I rented a VAG tool and everything related to the MMI says "cannot be reached".
So, one of my questions is...is there a way to pinpoint which component of the MMI system has failed using the VAG tool? Below is part of the report. Looks like I need brakes and a secondary air pump too (engine light?)
Is this the correct forum for this inquiry?
Thanks for any comments or advise.
Chris
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
Monday,03,February,2014,16:28:24:23581
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAUML44EX6N008069 Mileage: 175070km/108783miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Cannot be reached 1100
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E6770181
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E591B7AB94B586E36F-807B
2 Faults Found:
17831 - Secondary Air Injection System; Bank 1
P1423 - 002 - Insufficient Flow - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 174809 km
Time Indication: 0
Freeze Frame:
RPM: 844 /min
Load: 30.2 %
Speed: 19.0 km/h
Temperature: 22.0°C
Temperature: 18.0°C
Absolute Pres.: 0.0 mbar
Voltage: 13.335 V
17819 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 174809 km
Time Indication: 0
Freeze Frame:
RPM: 844 /min
Load: 30.2 %
Speed: 19.0 km/h
Temperature: 22.0°C
Temperature: 18.0°C
Voltage: 13.335 V
Readiness: 0000 0000
Address 0E: Media Player 1
Cannot be reached
Address 0F: Digital Radio
Cannot be reached
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H10 0080
Revision: 10 Serial number: 190030570780D9
Coding: FCFE7BDD1B7904
VCID: 2757EE5E96B10926F59-8072
No fault code found.
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H07 0160
Revision: 01604707 Serial number: AUX3Z0E6770181
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8B51DA26B4FF6DE0C3-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 2855ED629BAF065EFC3-807D
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
VCID: 2045F542F39FFE1EB43-8075
1 Fault Found:
02124 - Exterior Door Handle Switch
008 - Implausible Signal
Freeze Frame:
Fault Status: 01101000
Fault Priority: 3
Fault Frequency: 0
Reset counter: 194
Mileage: 144048 km
Time Indication: 0
Date: 2013.01.21
Time: 08:39:48
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number:
Address 47: Sound System
Cannot be reached
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000532
Shop #: WSC 22103 444 11918
VCID: 1F47F6BECEE1C1E68D9-804A
2 Faults Found:
02596 - Rear Brake Pads Worn
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 73
Reset counter: 209
Mileage: 173976 km
Time Indication: 0
Date: 2014.01.21
Time: 20:49:48
Freeze Frame:
Voltage: 11.90 V
Count: 60
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 2
Reset counter: 209
Mileage: 173976 km
Time Indication: 0
Date: 2014.01.21
Time: 20:49:46
Freeze Frame:
Voltage: 11.80 V
Count: 61
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Revision: 00000001 Serial number:
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000013065
Shop #: WSC 08214 444 67427
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1507180341
Coding: 344530393135313035412056413031353037313830333431
Shop #: WSC 00000 128 00289
3 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 160321 km
Time Indication: 0
Date: 2013.08.14
Time: 14:01:23
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 160321 km
Time Indication: 0
Date: 2013.08.14
Time: 14:07:51
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 4
Reset counter: 20
Mileage: 174489 km
Time Indication: 0
Date: 2014.01.28
Time: 12:16:30
Address 67: Voice Control
Cannot be reached
Address 77: Telephone
Cannot be reached
End ---------------------------------------------------------------------
Old 02-03-2014, 04:07 PM
ESICA14's Avatar
I ran a standard and 3dB optical bus test as well
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway OK OK
07-Control Head ERROR ERROR
0E-Media Player 1 OK OK
77-Telephone OK OK
47-Sound System ERROR ERROR
67-Voice Control OK ERROR
56-Radio OK ERROR
37-Navigation OK ERROR
0F-Digital Radio ERROR ERROR
Optical Bus Diagnostic : 3dB Attenuation
19-CAN Gateway OK ERROR
0E-Media Player 1 OK ERROR
77-Telephone OK ERROR
47-Sound System OK ERROR
56-Radio OK ERROR
0F-Digital Radio(SAT) OK ERROR
Old 02-03-2014, 06:50 PM
ESICA14's Avatar
Maybe the battery? Looks like the MMI quit about the same time as that third battery fault.
Old 02-03-2014, 10:19 PM
MP4.2+6.0's Avatar
Default Dying battery is always a suspect
Lots of posts over the years about a variety of gremlins that ultimately get tied to a battery on its way out. Have you checked yours, or has it run down on you recently. If so and/or its more than 4-5 years old, consider replacing. May or may not fix other stuff, but if it shows distress signs, its days are numbered anyway.
After resolving that, I would clear all the codes and then see what comes back and/or functions.
On your brakes, look at them physically. Are the rear pads pretty worn down or not? If not, it's not uncommon to see some codes there (mine too), especially if any prior difficulty reseting the pad thickness setting in back when replacing pads.
On air pump, not too many seem to report the failure is ultimately there. Those codes also come up when there are issues in either the vacuum lines or in the intake plumbing--loose clamps and such. Check those areas first and then clear the related codes and see if they come back--takes several driving cycles to confirm either way (and turn on CEL).
Old 02-03-2014, 10:49 PM
mishar's Avatar
Have you checked fuses? Start with fuse 12 in the dashboard right fuse box. It is for MMI Control Module (7).
Old 02-04-2014, 01:08 AM
ESICA14's Avatar
Thanks...
I'll check the fuse...
The battery hasn't exhibited signs of failure but it is old and I have some codes so I'll change that next. I imagine aftermarket is okay? If not please comment.
Where would I find the Secondary Air pump and hoses...under the airbox? So I'll need to remove the front underbody panel?
Sorry for all the questions.....I haven't worked on this car much, or at all.
And once again, thank you for your comments.
Chris
Old 02-04-2014, 10:03 AM
ESICA14's Avatar
Fuse #12 is good......bought a new battery and will replace it today...fingers are crossed.
Old 02-04-2014, 12:33 PM
ESICA14's Avatar
Checked fuse, okay. Installed a new battery and no change.
Cleared the CEL and it has remained off...bought new rear brake pads, I'll handle that later.
Re-scanned after the battery and have two new faults: I'm headed in the wrong direction!!
Any comments would be greatly appreciated.
Thanks,
Chris
VCDS -- Windows Based VAG/VAS Emulator
VIN: WAUML44EX6N008069 License Plate:
Mileage: 175110km-108808mi Repair Order:
VIN: WAUML44EX6N008069 Mileage: 175110km/108808miles
03-ABS Brakes -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
Coding: 0007773
2 Faults Found:
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0°C
Voltage: 0.000 V
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 175110 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 85.0°C
Temperature: 76.0°C
Voltage: 11.938 V
Readiness: 0010 1000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 E HW: 09E 927 156 B
Component: AG6 09E 4,2L5V USA 0110
Revision: --H01--- Serial number: 0063280
Coding: 0000002
Shop #: WSC 22103 444 85745
VCID: 254BE456ECBD1B36C75-8070
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 2241FF4AFD93EC0EA27-8077
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H01 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
VCID: 244DF952E787E23ED0B-8071
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000072361
Coding: 1052993
VCID: 1C3DC1B2DFF7DAFE68B-8049
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E0 907 279 L
Component: ILM Fahrer H13 0210
Coding: 0143123
VCID: 31630006A87547962BD-8064
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000037
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
Cannot be reached
Cannot be reached
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0001MP+
Coding: 0532707
Shop #: WSC 22163 444 57952
VCID: 2649E35A91BB102ECEF-8073
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 34971
Subsystem 3 - Serial number: 0001.01.0000H0100000000000˙†63
Subsystem 4 - Serial number: 000000˙†63328RB40083236DD˙†63
Subsystem 5 - Serial number: 3236DD˙†63428RB4008323F4E˙†63
Subsystem 6 - Serial number: 323F4E˙†63528RB40083235AB˙†63
Subsystem 7 - Serial number: 3235AB˙†63628RB4008322FCN˙†63
Subsystem 8 - Serial number: 322FCN˙†63729RB4008CF54B ˙†63
Subsystem 9 - Serial number: CF54B ˙†63829RB4008CF794$˙
Subsystem 10 - Serial number: CF794$˙
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0310
Revision: 00H01000 Serial number: 90025050990111
Coding: 0012241
Component: E0221 H02 0100
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 Q HW: 4E0 920 950 Q
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3E6001479
Coding: 0048263
Shop #: WSC 26105 444 10310
VCID: 32610F0AAD737C8E527-8067
1 Fault Found:
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 6
Reset counter: 24
Mileage: 175077 km
Time Indication: 0
Date: 2014.02.03
Time: 04:57:54
Coding: 0410624
Component: ELV XXXX
Coding: 0015510
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H01 0010
Coding: 4071530
Cannot be reached
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000518900017
Coding: 0003477
VCID: 1D3BCCB6C4EDD3F69F5-8048
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 194
Mileage: 144048 km
Time Indication: 0
Date: 2013.01.21
Time: 08:39:48
Revision: 00100005 Serial number: W040507140054
Coding: 0048702
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
Cannot be reached
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000066044
Coding: 0010111
VCID: 1E39CBBAC9EBC8EE86F-804B
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T0MMXE
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032364
Revision: A32C0220
Coding: 0000532
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 84
Reset counter: 209
Mileage: 173976 km
Time Indication: 0
Date: 2014.01.21
Time: 20:49:48
Freeze Frame:
Voltage: 11.90 V
Count: 60
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 209
Mileage: 173976 km
Time Indication: 0
Date: 2014.01.21
Time: 20:49:46
Freeze Frame:
Voltage: 11.80 V
Count: 61
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio
Cannot be reached
Component: von TU3 1507180341
Coding: 344530393135313035412054553331353037313830333431
Shop #: WSC 12345 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000900033191
Coding: 0232125
VCID: DFC736BE0E6101E64D9-808A
Cannot be reached
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0020
Revision: 00H12000 Serial number: 08720519200557
Coding: 0201308
VCID: 234FFA4EE289E506A91-8076
Cannot be reached
Old 02-04-2014, 03:51 PM
mishar's Avatar
77-Telephone OK OK
56-Radio OK ERROR
56-Radio OK ERROR
As far as I can see problem is here. Nothing from your optical ring can be reached. You should find optical loop and try bypassing modules one at the time. Start in the trunk it is easiest. Phone is underneath drivers carpet and the rest behind the glove box. If the system start s working it is bypassed module. Or at the end MMI Control Module. I hope this helps.
Old 02-04-2014, 04:03 PM
ESICA14's Avatar
How exactly do I bypass a component? Is there an "in" and "out" cable?
If so wouldn't that leave the circuit open? Is a coupling necessary?
Quick Reply: 2006 MMI Help....Please
