Low fuel warning question
Old 01-30-2014, 02:37 PM
S4thrills's Avatar
Default Low fuel warning question
I am aware that when you hit the 1/8th tank level, the fuel gauge LED light turns red. This morning I learned when you get below a certain level, it starts flashing red.
Any idea how much fuel remains at the point it starts flashing? I was able to get to a fill station and the car took 17.998 gallons with no topping off. Just wondering how close I ended up cutting it.
TIA!
Old 01-30-2014, 02:57 PM
gatorguy7's Avatar
Never got to the point that it flashed red before...
Thanks for sharing though. I'm sure you know its bad to run cars that empty right?
Old 01-30-2014, 03:03 PM
MalibuCANE's Avatar
I just go as soon as it turns red so I don't run any debris through the fuel lines but that's good to know.
Old 01-30-2014, 03:04 PM
S4thrills's Avatar
I know, generally, it isn't good to run a car to empty. However, still trying to figure out how empty I really was. I haven't pulled the manual, but I read somewhere the fuel capacity is 19.8 gallons. I filled 18, which implies there was another 1.8 in there. But that still feels like a lot to have in the tank for it to start flashing red. But maybe they just program the warning to be super conservative.
Old 01-30-2014, 03:40 PM
gatorguy7's Avatar
Wow, I didn't realize that the official tank size was 19.8. That would suggest that the low fuel warning is really conservative.
Old 01-30-2014, 05:15 PM
S4thrills's Avatar
I just RTFM and it does say 19.8 capacity and it also says the reserve is 2.6 of the total capacity so they must build in a ton of cushion for slackers like me.
Old 01-30-2014, 06:43 PM
gatorguy7's Avatar
2.6 of the 19.8 is reserve? Or is that in addition, if so, that would be crazy and give it a much longer range. Although it wouldn't be practical since most won't drive that long in the red.
Old 01-30-2014, 07:13 PM
snagitseven's Avatar
As stated, "the reserve is 2.6 of the total capacity".
Old 01-31-2014, 02:18 AM
Vijay's Avatar
Unfortunately, none of this tells you exactly how much fuel you have left when your gauge starts flashing. 2-2.5 gallon reserve is not uncommon. My M3 gives you a warning signal when you get to just below 1/4 tank, or less than 4 gallons. My Previous Porsche Cayenne, has a 26 gallon tank but the gauge would be down to "0 miles" and I would fill up with under 23 gallons.
Old 01-31-2014, 05:18 AM
HyperS4's Avatar
FWIW, pretty much every car we get comes to the dealership off the truck with the red light blinking or just about there.
I personally have run to where it states 0 miles left and blinking red and drove another 25 miles till I found a station.
The most Ive ever filled my tank was the first tank it ever had(off the truck) and I filled it with 18.30 gallons.
Quick Reply: Low fuel warning question
