TT (Mk2) Discussion Discussion forum for the Mk2 Audi TT, TT-S and TT-RS Coupe & Roadster produced from 2007-2014
white milky goo under oil cap???
Old 01-26-2014, 01:55 PM
mpmiller37's Avatar
Default white milky goo under oil cap???
I checked my oil today and decided to add a quart because it burns a little every few thousand miles. When I took off the oil cap this is what I found, see pic below. Also the inside of the tube where you fill with oil had a lot of this whitish milky colored goo around it. Car runs fine and the dealer just changed my oil 1000 miles ago and didn't indicate any problem. Anyone seen this before?
Thanks,
Mike
2008 Audi TT Roadster 44k miles
Old 01-26-2014, 02:17 PM
Head Cat Herder
Kris Hansen's Avatar
That's water vapor residue. Fairly normal in cold weather, when you make short trips. You want to let the car warm up a bit more, to allow the oil to burn off the water which naturally occurs.
Old 01-27-2014, 04:44 AM
Vegas-roadsTTer's Avatar
Default Coolant in the oil can cause that
Thanks,
Mike
Old 01-27-2014, 11:25 AM
mpmiller37's Avatar
Looks like Mr. Hanson was correct, my local dealer stated this:
That is normal--the whitish milky goo is a mix of the water vapor and engine oil. Water vapor from the positive crank case ventilation is formed from the temperature change in the engine against the outside ambient air temperature. With the extreme cold we have been having, it is now more pronounced.
Appreciate the responses as I was a little freaked out !!!
Old 01-27-2014, 02:48 PM
skl1's Avatar
Very common- my '71 914 does that in colder weather, done it since 1971... nothing to stress about.
Old 01-29-2014, 02:50 PM
Head Cat Herder
Coolant will make ALL of the oil look like that though, not just the little bit on the cap. If you pull the dipstick out and it looks like chocolate milk, you have a problem. If not, you're fine. =)
eddierocks16
20
04-20-2016 12:36 PM
2014a6tdi
A6 (C7 Platform) Discussion
05-07-2015 07:27 PM
nyc1212
08-31-2005 07:12 PM
bryantchoung
Audi allroad
9
06-11-2003 06:59 PM
jchan
12
08-21-2002 10:09 AM
Quick Reply: white milky goo under oil cap???
