Old 01-26-2014, 07:33 AM   #1
kcosh
Account #: 230915
Default Tensioning lever hole threads stripped
In the process of replacing some components AGAIN!, found that threaded hole where tensioner bolts mounts the tensioner is stripped, any ideas on how to remedy? That oil pump cover is a pain to remove on vehicle.
kcosh is offline   Reply With Quote
Old 01-26-2014, 10:49 AM   #2
tester123
Account #: 171699
tester123's Avatar
I'd imagine the easiest thing is to create new threads with a tap next size bigger than current size. You might have to drill/expand the hole on the tensioner as well.
ʘ˥ Pearl White А6 Ч.2ℓ Quattro
Sport, cold, everything -Nav.
No more OIL or COOLANT leaks! │ T-Belt, Water pump & Valve Covers DONE! │ Trans & Diff Fluid DONE! │ Bearing & Inner Tie-rod Next │ Steering leaks?
Fuel Banks 1 & 2 Lean issue fixed (finally!)
Rebuild Bosch 150 Amp Alternator (save major $$$)
tester123 is offline   Reply With Quote
Old 01-26-2014, 02:06 PM   #3
SloopJohnB@mac.com
Account #: 44417
SloopJohnB@mac.com's Avatar
That's easy...helicoil.
It will be stronger than the original if not the larger hole someone recommended. Plus te regional bolt size in the tensioner will work well.
SloopJohnB@mac.com is offline   Reply With Quote
Old 01-26-2014, 02:08 PM   #4
SloopJohnB@mac.com
Account #: 44417
If u can do this you can helicoil it and don't have to mess with the tensioner.
Old 01-26-2014, 06:21 PM   #5
tester123
Account #: 171699
tester123's Avatar
I must say, never used it. But will keep in mind for future .
Old 01-28-2014, 02:36 AM   #6
kcosh
Account #: 230915
I thought of the helicoil immediately but upon further investigation I noticed there was still about a 1/2 " of threads left in the hole. So I found longer bolt from my German xtras bolt box - probably from a BMW, chased the threads and sized the bolt appropriately, voila!. Hind sight tells me that something so important as a bolt for this purpose should utilize as many threads as possible - common steel to aluminum oil pump cover. Next one I do I will probably use longer bolt.
Old 01-28-2014, 04:43 AM   #7
SloopJohnB@mac.com
Account #: 44417
I suspect the longer bolt will strip out as well. Should have helicoiled it. Downside of tensioner failure is bent valves on both heads or a broke piston, dead engine.
Forum Jump
