'06 A8 timing belt controversy
Old 01-25-2014, 08:22 AM
figleaf11's Avatar
Default '06 A8 timing belt controversy
Have an '06 A8 mfg'd in Oct '05, dealer tells me the change from belts to chains was made in July'05. They say my engine code is BGK so it takes a toothed belt. Trying to make sense of that. Is there a physical exterior difference in the belted and chain engines?
Thanks guys, Ralph
Old 01-25-2014, 08:39 AM
MP4.2+6.0's Avatar
Default Find a new dealer!
Pardon my French, but the person at your dealer is incompetent on the subject. F in Audi product knowledge.
To i.d. them, an easy way is just look for the covers where the belt is--about an inch and a half of various covers directly in front of the cylinder heads and then downward all around the front of the motor in various shapes. The serpentine fan belt is run yet further forward in front of those, as opposed to much closer in my the actual motor castings.
I would have to look at intro dates, but the reference is likely to the C6 A6, which I think was probably the first one introduced with the FSI (non belt) motor among the 4.2's.
Old 01-25-2014, 08:41 AM
2k6blacka8's Avatar
04-06 timing belts are the same design and tooth and everything. 07 is when they started going to timing chains(no more timing belt).
Old 01-25-2014, 08:45 AM
mishar's Avatar
2003 - 2006 came with BFM engine. They have timing belt. It is at the front of engine under the black plastic cover.
2007 - 2010 came with BVJ engine. They have chains driving everything but generator. They are at the back of engine, so no plastic covers at the front. On the top of those engines you can find FSI, meaning Fuel Stratified Injection.
Old 01-27-2014, 02:24 PM
figleaf11's Avatar
It is definitely a BGK and has a belt. Although mfg'd in Oct of '5 they were probably using up belted engine inventory.
Any opinions on a good belt kit?
Thanks fellows,Ralph
Old 01-27-2014, 04:50 PM
mishar's Avatar
No. They switched to BGK for MY 2007.
Edit: I should said BVJ.
Old 01-27-2014, 05:07 PM
jandreas's Avatar
This is from a MY06.
Old 01-27-2014, 05:14 PM
mishar's Avatar
Month?
Old 01-27-2014, 05:19 PM
jandreas's Avatar
Originally Posted by mishar
Month?
I would find that where?
Old 01-27-2014, 07:10 PM
mishar's Avatar
What is the tenth digit in your VIN?
Quick Reply: '06 A8 timing belt controversy
