Go Back   AudiWorld Forums > AudiWorld Community > Vendor Showroom
Vendor Showroom A place where vendors may display their wares
Old 01-24-2014, 02:16 PM   #1
Blauparts Sales
Audiworld Premium Sponsor
Account #: 146870
Default Blauparts: Brake & Gear Lube On Sale - Extra 10% Off Sale Prices use Code LIQUID14
Brake Fluid & Gear Lube at Great Liquidation Prices Plus Take An Extra 10% Off w / Code LIQUID14
RAVENOL BRAKE FLUID
Changing your Audi's brake fluid is recommended and most conveniently done when performing Audi brake rotor or pad service. Did you know that in a 3 year period (average of 15,000 miles a year) drivers depress the brake pedal approximately 225,000 times? Brake fluid is made of a glycol oil base which inherently attracts moisture from the atmosphere. Overtime the brake fluid becomes more contaminated with moisture, changing it's composition and affecting it's ability to stop the car. It also lowers the boiling point of the fluid. This is dangerous and decreases the car's stopping power in emergency stopping situations, where high temperatures are generated from the hot rotors and pads and then into the brake calipers (which function using brake fluid). Audi brake fluid flush should usually be performed every 30,000 miles or 3 years. This is especially important in parts of the country where high humidity is common. Check the owners manual or look at the brake fluid reservoir cap for recommended spec.
Using the correct type of brake fluid is important. Ravenol DOT 4 and DOT 5.1 Audi brake fluid meets necessary fluid specifications. Ravenol brake fluid's additive formulation provides the best braking characteristics in all conditions and offers full lubrication in ABS systems, hydraulic braking, clutch systems, and gives reliable performance in everyday driving or in the frequent braking conditions of extreme stop-and-go city driving. Read more...
Product Information:
Ravenol DOT 5.1 is a high performance street or racing brake fluid designed for vehicles fitted with modern braking and ABS systems. Ravenol DOT 5.1 brake fluid offers specially selected additives for superior braking in extreme conditions.
Ravenol DOT 5.1 Features:
1 Liter Bottle (1000ml).
Mfd. in Germany by Ravenol.
Gold in color.
Applicable for hydraulic braking and clutch systems.
Compatible with all brake systems requiring DOT 5.1 brake fluids.
Exceptional performance. This Audi VW brake fluid has a dry boiling point of 536 F and a wet boiling point of 356 F.
Gives ABS and brake systems optimum efficiency and lubrication.
Long life Audi VW brake fluid with 3 year change interval.
Designed for excellent resistance to moisture absorption.
The perfect Audi VW brake fluid for all performance driving conditions.
Audi Vw Brake Fluid - Ravenol DOT 5.1
Audi Vw Brake Fluid - Ravenol DOT 5.1 - Case of 6
Ravenol GL-4 is classified as high performance gear oils. Ravenol gear oils (aka transmission fluid) are specifically engineered for European transmission requirements. Ravenol has formal approvals from ZF transmission, the world largest German transmission manufacturer.
The latest manual transmissions and differential designs require unique performance characterized gear oils to ensure long life performance. Ravenol gear oils provide the proper friction balance required for manual transmission syncros, ensuring smooth consistent shifting, even under high RPM load (racing) conditions. Due to it's unique formula, Ravenol gear oil supplies excellent extreme pressure (EP) characteristics, low pour points with a high viscosity index (film strength), and also provides extreme high pressure absorption (shock load) capacity. Ravenol gear oil is available for hypoid and non-hypoid transmissions, providing excellent aging resistance for extended change intervals. Ravenol gear oil is the right choice in providing maximum protection for your specific European application.
Why Change Your Manual Transmission Or Rear Differential Gear Lube?
Plain and simple, systems with moving parts such as bearings, gears, and syncro rings meshing with one another will eventually require servicing. Over time, metallic particles from the interaction of these parts contaminate the gear lube. Significant amounts of metallic particles present in the gear lube can accelerate wear in the bearings etc. For optimal longevity of both the manual transmission (stick shift) and the rear differential (Quattro / 4Motion / AWD models), Blauparts recommends changing gear lube every 60,000 80,000 miles.
Ravenol TSG Gear Lube Information:
Ravenol TSG Synthetic Hydrocrack Gear Lube - Mfd In Germany
Ravenol TSG 75w90 is a high performance semi synthetic hydrocrack gear lube for manual transmissions requiring specification GL-4. Ravenol TSG contains high quality synthetic and hydrocrack base oils with a special inhibiting additive formulation to give the ultimate transmission protection in all situations.
Ravenol TSG Features:
Meets Vw / Audi 501 50, G50 specification
Excellent aging resistance
Extreme high pressure capabilities
Optimum viscosity temperature behavior in cold and hot climates
Extreme low pour point
Outstanding wear protection and lubrication in highly stressed conditions
Excellent oxidation, corrosion, and foaming resistance
Suitable in manual transmissions with or without synchros
Other features and specifications:
SAE 75w90
API GL-4
FORD ESD M2C-175-A
GM B 040 1043
OEM Reference: Vw/Audi 501 50 (G50), Vw G 052 911 A2, G 005 000, G 055 726 A2
Audi Vw Transmission Gear Lube - Semi Synthetic - Ravenol TSG GL-4
Blauparts' Other Current Sales & Promotions
$30 Off BLAU Shock & Strut Replacement Kits Plus, save an additional 10% Off select OVERSTOCKED kits with Code NEW2014
$50 Off CLOSEOUT BLAU Shock Kits Plus, save an additional 10% Off select CLOSEOUT kits with Code NEW2014
$50 Off Allroad Lower Control Arm Kits
Blauparts' Popular Repair Kits
BLAU Brake Rotor & Pad Kits
BLAU ATF Filter Change Kits
BLAU Timing Belt Replacement Kits
BLAU Valve Cover & Cam Chain Tensioner Gasket Kits
BLAU Ocap Complete Control Arm Kits
Ravenol of Germany Oils & Fluids
Website:
www.blauparts.com
* Free shipping offers are for FedEx Ground shipping to 48 US contiguous states only. Liquidation Inventory is subject to stock on hand, when its gone its gone. Offers End 2/3/2014
Blauparts Sales is offline   Reply With Quote
audi brake fluid, audi gear oil, blauparts, ravenol gear oil, transmission fluid
Forum Jump
