Cold weather woes
Old 01-22-2014, 08:09 AM
steveinky's Avatar
Default Cold weather woes
'01 A6 2.8 Quattro: Below zero this AM and hard to start. Car popped and bucked and I had to keep my foot on the gas for a few minutes before it ran normally. Had similar experience last year and replaced coolant temp sensor and that fixed it. Same problem again?
Then 10 miles later I smelled gas, pulled the engine cover and the high pressure hose going to the fuel rail was dripping. I shut it off to think about and after it dried off, I started it back up and no drip!~? So I think maybe the super cooled gas shrunk the o-ring enough to allow it to drip. Anyone experienced that?
Any insight is appreciated.
Steve
Old 01-22-2014, 08:15 AM
tester123's Avatar
Steve
Time to change O-Ring and/or fuel line if it is pressure fitted.
"Cold" starts can be troublesome. Add some dry gas in winter to tank to remove any moisture.
Old 01-22-2014, 01:12 PM
Airbag's Avatar
Sounds like it could have been a frozen fuel return line too.. Keep the car above half a tank during extreme cold weather.
dantal0
30v V6 Discussion
11-15-2017 09:46 AM
Ertman
08-26-2009 02:59 AM
sidespar
10
11-24-2008 07:28 AM
caidyn03
11-20-2008 08:32 AM
jotax2
07-15-2004 04:57 PM
Quick Reply: Cold weather woes
