Recoding key fob
Old 01-20-2014, 06:41 AM
JF1957's Avatar
Default Recoding key fob
Hi, i got an 2005 A4 cab and i've been disconnecting the battery to do some work. After reconnecting it i reprogramed the clock, windows and key fob. Everything is working just fine exept the open/close windows and top from the key hole driver side door. I tried and done different way to recoding the key fob remote but its always the same. I notice that when i lock the doors with the remote, the little red light is flashing about nine to ten times rapidly.
Anything will help
Best regards
Old 01-22-2014, 12:07 PM
tofast2belast's Avatar
Anything will help
Best regards
the light blinks that fast then should return to blink every 2 seconds.
as for the windows. put key in to on position,
press and hold window switch down all the way(click the auto down)
youll hear the window motor stop.
then release and do the same to bring it up.
then test the auto down/up. do this for all windows.
the module needs to "learn" the position and limit of the windows before the auto function/keyfob will work.
Old 01-23-2014, 06:15 AM
lyleswk's Avatar
That's good info. Didn't even know you could roll the windows down with the fob. Have to try that on mine...
Old 01-23-2014, 06:20 AM
JF1957's Avatar
When i first read your suggestion i was septic having trying sooooo many things. Whatever i try it as i try all the other suggestion that i had received and find on the net. Well let me know that it resolved my issue and that i'm very thankfull to you.
Its amazing to see i those forum help peoples. THE POWER OF US.
Again thank you
Old 01-23-2014, 09:05 AM
with the key, oem is put key in door lock and turn to unlock and hold the windows will go down, to bring them back up, turn to lock position.
with vag com
you can press and hold the lock button to close windows and sunroof(if open)
press and hold unlock button to open windows.(will not open sunroof)
Old 01-23-2014, 10:32 AM
JF1957's Avatar
with vag com
And with the cab (my case) turn unlock twice in the door lock open your soft top, and twice lock closed it, fantastic.
Regards
MJL3297
02-01-2011 12:08 PM
Farb
01-27-2009 10:34 AM
nemesisa6
02-03-2008 02:28 PM
Tommasini
A4 (B7 Platform) Discussion
07-24-2006 07:46 PM
audiringpwr
02-07-2003 04:42 PM
Quick Reply: Recoding key fob
