Oil analysis TDI @ 625km
Old 01-17-2014, 12:02 PM
  #31
Superfly_A6's Avatar
Default Hello Uber
Uber, your persistence and confidence made me do some digging. You are right. The dealer gave me the wrong information. I went to the dealer and requested to see the type of oil they use on diesels. This is what they showed me:
It appears I was given the wrong information. All is safe and DPF will live on. This is part of the reason oil analysis showed properties similar to 0w30.
Thanks for clarifying.
Old 01-17-2014, 02:15 PM
  #32
uberwgn's Avatar
Awesome ! You can count on the forums for mostly valid info! Good luck with it.
Old 01-18-2014, 05:37 PM
  #33
Bob Petruska's Avatar
Default Notice the high phosphorus/zinc readings....
Originally Posted by Richard Solomon
There's a ton of great info here on Audiworld, make you own decision on the correlation. My experience is posted just to say that as one who followed the breakin and first oil change and is not having excessive consumption. What I remember of these decade-old discussions is that of the people complaining of excessive consumption, many/most had changed early. That doesn't mean that everyone who changed early had problems, just that it appeared that there was a strong correlation between having problems and having changed early.
One theory is that modern machining tolerances are so tight that rings *NEED* those suspended metal particles to seat properly. I'm an electrical engineer, not a mechanical engineer, so I'm staying mostly out of that. Search the forums, read the postings, make your own decision - just make it informed, not based on 20-30yo conventional wisdom. YMMV, professional driver on closed course, etc, etc, etc.
in the OP's printout. Phosphorus/zinc is used in breakin oil to protect high pressure wear areas (camshaft tappets, etc.). Breakin oil usually doesn't contaim much, if any, super anti-wear additives to help seat the rings to cylinder walls.
It will be nice to see the OP's next oil change printout, I would guess the phosphorus/zince levels to be much, much lower.
Old 01-18-2014, 06:43 PM
  #34
I'm changing the oil this Monday, and sending it out for analysis. Should be clear next Thursday or so.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
audiinnj
9
12-05-2018 04:31 AM
dbdubb
Q7 MK 1 Discussion
09-10-2015 04:17 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
Quick Reply: Oil analysis TDI @ 625km
