NEWBIE NEEDS HELP!
Old 01-09-2014, 02:49 AM
William_Audi's Avatar
Default NEWBIE NEEDS HELP!
Hey all,
Im new to the forum.
I have brought an Audi A4 B5 1998 wagon (1.8L)
I brought it with some problems, however there is one I can't work out.
There is a slight shudder/misfire at idle. The mechanic I took the vehicle to has checked the injectors, the coil pack, leads and plugs were changed.
I am yet to check the MAF and underneath the rocker cover for sludge build up.
Today I noticed a bit of a tappet noise as well.
More information regarding the shudder/misfire:
Only present at idle
When accelerating it disappears
There is a slight bit of lag when under heavy acceleration
Stalls on cold start
Small amount of engine movement at idle
The car has 180000kms on it and I have added a valve lifter additive to try and free what I think may be a stuck hydraulic tappet.
The mechanic said there was a slight decrease in pressure in cylinder 3 at start up also.
I am yet to do an oil and filter change because I would like feedback beforehand.
Thanks,
I look forward to the response of the forum
Old 01-09-2014, 03:00 AM
Tech Guru
4Driver4's Avatar
Congrats on the buy.
You have no tappets. Do not add any more snake oil. How old are the spark plugs? Right plugs? What codes are you seeing, if any?
Old 01-09-2014, 03:43 AM
I have hydraulic lifters?
The plugs were replaced by the mechanic when the coil pack was replaced.
I haven't got a scanner because i don't plan on keeping the car. it is for resale but i want to have it in good order before doing so.
Any further ideas?
Old 01-09-2014, 04:07 AM
Tech Guru
4Driver4's Avatar
Without codes, you basically have nothing and all you can do it guess. :-(
Old 01-09-2014, 04:29 AM
who gives codes locally? Audi dealer? how much does it cost etc?
Old 01-09-2014, 05:30 AM
Huskerbob's Avatar
Most parts stores will pull the codes for you free of charge. It won't be VAG but at least you should be able to get the codes. Start with that.
Old 01-09-2014, 12:12 PM
AudiMick's Avatar
You can buy a generic hand held OBDII code reader that will work with most US 1996 and newer vehicles for under $60, false economy to try to fix it without.
E-bay has them even cheaper.
Old 01-09-2014, 04:13 PM
jseklund's Avatar
Or if you post your location and/or look around, you may find someone who has a vag-com and will help you out for beer or a pat on the back.
Old 01-24-2014, 12:30 AM
Hey guys, got my hands on a VAGCOM scanner but i need someone to help decode them:
VAG-COM Version: Release 409.1-US
Control Module Part Number: 8D0 907 558 B
Component and/or Version: 1,8L R4/5V MOTR HS D03
Software Coding: 04001
Work Shop Code: WSC 06325
10 Faults Found:
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
01120 - Shareware Version. To Decode all DTCs
04-10 - Please Register/Activate - Intermittent
01165 - Shareware Version. To Decode all DTCs
17-10 - Please Register/Activate - Intermittent
17972 - Throttle Actuator (J338): Under-Voltage during Basic Setting
P1564 - 35-10 - - - Intermittent
17967 - Shareware Version. To Decode all DTCs
P1559 - 35-10 - Please Register/Activate - Intermittent
01249 - Shareware Version. To Decode all DTCs
26-10 - Please Register/Activate - Intermittent
01250 - Fuel Injector for Cylinder 2 (N31)
26-10 - Output Open - Intermittent
01251 - Shareware Version. To Decode all DTCs
01252 - Shareware Version. To Decode all DTCs
00515 - Camshaft Position (Hall) Sensor (G40)
30-10 - Open or Short to B+ - Intermittent
Old 01-24-2014, 02:55 AM
Tech Guru
4Driver4's Avatar
Google is your friend.
Quick Reply: NEWBIE NEEDS HELP!
