Automatic say push in clutch....
Old 01-04-2014, 10:59 AM
werick's Avatar
Default Automatic say push in clutch....
I have a automatic that has been havin issues starting. I believe it is the FRV but the problem is that is coming into playnow is that if i try to start for so long i ened up draining the battery and then it tell me to push in clutch to start vehicle. What could be the the reason for this issue if i dont have a man tranni??
Old 01-04-2014, 11:20 AM
snagitseven's Avatar
What model/year do you have, where are you located and what's an "FRV"?
Old 01-04-2014, 12:57 PM
werick's Avatar
98 A6 Quatt and fuel press reg vavle
Old 01-04-2014, 01:57 PM
Superfly_A6's Avatar
Just a suggestion, this is the wrong model forum for your question, try the C5 forums
Old 01-04-2014, 04:04 PM
tenspeed's Avatar
Hard starting in the cold is a common problem in older cars. Compression is down and nothing works as well as when new. It could be that the fuel pressure regulator is leaking down when parked causing a lean mixture at start up.
Try turning the key to "On" a couple of times before turning the engine over. That allows the fuel pump to cycle and raise the pressure in the fuel rail so the engine gets a richer mixture at start up. Make sure that the battery, plugs and wires are up to snuff too.
As for the push in the clutch warning, it could be that the wrong program was uploaded into the car. I would be more worried about the car starting than warning messages.
Old 01-04-2014, 06:21 PM
werick's Avatar
Yea changin forum but if anyone knows please help i just bought a fprv and it still working...
Mesa512
S4 (B8 Platform) Discussion
20
07-07-2018 11:23 AM
lmariorod
10-26-2017 11:39 AM
Hours of Service
New Member Welcome Area
06-29-2017 05:07 PM
Tinbad
A6 (C7 Platform) Discussion
9
10-23-2015 12:47 PM
gorkyc
10-04-2015 07:00 PM
Quick Reply: Automatic say push in clutch....
