Go Back   AudiWorld Forums > Audi Models > Audi A6 / S6 / RS 6 > A6 / S6 (C6 Platform) Discussion
Old 01-02-2014, 09:36 AM   #1
mkongsiri
Account #: 274027
Default 2005 A6 3.2 FSI Timing Chain Tensioner
It looks like my V6 3.2 FSI engine has a failed chain tensioner (loud rattling). I've ordered a set of upper tensioners for both banks and will attempt to replace them when the parts arrive.
I've read on other forums that the tensioner failure is common on these engines. I'd like to try just changing just the upper tensioners as Im not looking forward to pulling the engine without a lift to do all the chains. Has anyone on this forum attempted this?
mkongsiri is offline   Reply With Quote
Old 01-02-2014, 04:11 PM   #2
mill3241
Account #: 243675
I think I'm having the same issue as you. Please let me know how it goes if you do attempt to fix.
Also, where did you buy tensioners and how much?
mill3241 is offline   Reply With Quote
Old 01-02-2014, 04:22 PM   #3
mkongsiri
Account #: 274027
I ordered them from partsgeek.com
Parts Ordered
2005 Audi A6 Quattro Timing Chain Tensioner Engine Mechanical Price: $218.98 Core: $0.00 Extended Warranty: $0.00 Qty: 1 Part #: W0133-1773921
2005 Audi A6 Quattro Timing Chain Tensioner Engine Mechanical Price: $171.98 Core: $0.00 Extended Warranty: $0.00 Qty: 1 Part #: W0133-1773922
I haven't been able to find anyone that has posted anything remotely usefull on this topic besides a few pictures and that it has to be a $8k engine pull ordeal. I'm not interested in replacing the lower chains so will post pictures when I tear into this.
Old 01-02-2014, 06:07 PM   #4
newa6er
Account #: 234420
How do you know it's an upper tensioner? If you have access to a VAG-COM you can diagnose which tensioner is bad. I have been fortunate to not have any experience with the tensioners. I have read that the only tensioner that you can change with the motor in the car is the upper L & R on the 3.2. The motor has to come out to do anything on the 4.2. You will need to buy or rent a locking tool to keep everything in place while swap out the tensioner. Good Luck.
newa6er is offline   Reply With Quote
Old 01-02-2014, 06:49 PM   #5
mkongsiri
Account #: 274027
I can pretty clearly hear where it's coming from. Furthermore, lets look at this logically. If I replace both the upper tensioners and it resolves it then great. If it's the lower guides/tensioners then the motor has to come out anyway. If I'm replacing 1 tensioner, I'm going to do both. I've been working on Porsche/BMW engines since the early 80's. I've run across many failed chain tensioners, I'm not sweating too hard about this. I've ordered the Ross-tech vagcom but I have no intention of waiting, they're getting swapped.
Old 01-03-2014, 05:27 AM   #6
justincr250
Account #: 118525
Maybe do a write up on this to help us less skilled, please!!
justincr250 is offline   Reply With Quote
Old 01-03-2014, 05:40 AM   #7
mkongsiri
Account #: 274027
Yea, that's the plan. I'll see if I can shoot some video and put it up on youtube too. Parts get here next Monday, so I'll probably work on it Tuesday.
Old 01-29-2014, 05:08 PM   #8
Luis A.
Account #: 169499
Default Update?
Hey, I think I have the same issue on my 2008 with 80k miles. Loud rattling that lasts around a second or two upon startup.
I did a lot of work on my '98 A6, including timing belt but have done nothing major on this one. I have VAGCOM and the audi online service manual but would still love to see how it went for you.
Luis
Milwaukee, WI
'08 A6 Black/Black
'98 A6 185k miles
'96 Porsche C4S
'86 Citroen 2CV
'71 Fiat 500L
'03 Honda Odyssey
Luis A. is offline   Reply With Quote
Old 01-29-2014, 05:12 PM   #9
mkongsiri
Account #: 274027
I'm almost done with it, just waiting for the freezing 45 degree weather in Florida to pass! 70 degrees friday! I've documented the whole process, tools needed, parts etc. Have video too.
Old 01-29-2014, 05:26 PM   #10
Luis A.
Account #: 169499
Awesome! Look forward to it. Did only changing the upper tensioners resolve the noise?
2005, 32, a3, a6, audi, c6, chain, change, cold, quattro, rattle, rattles, start, started, timing
Forum Jump
