Brakes Discussion Discussion forum regarding brake tuning, upgrades and questions
Vibration when applying brakes
Old 12-26-2013, 05:45 PM
Whit1234's Avatar
Default Vibration when applying brakes
I had an certified Audi mechanic change all brakes and rotors on my Audi A8 2011 with 55,000 miles and now I have a vibration when I apply the brake around 50mph.I haven't noticed my steering wheel shake and I Don't have any noises. It seems like it starts with a slight vibration then the more I apply the brakes the harder the vibration becomes almost like you were having a flat tire. It seems like it's coming from the right front side. Any Ideas? Thanks for HELP.
Old 12-26-2013, 06:35 PM
tenspeed's Avatar
Take it back. You paid for for a brake job without the vibrations.
They'll probably try some brake cleaner and if it persists, they'll probably turn the rotor in a lathe to clean it up.
Old 12-30-2013, 05:43 AM
Just Me's Avatar
Did this occur immediately or come on slowly over a period of time? I have never seen warped rotors, even after race track use. OTOH, i have seen pad deposits all the time, btu they come on slowly.
In any event, take it back.
What pads were used?
Grant
Old 01-02-2014, 06:55 AM
Whit1234's Avatar
Originally Posted by tenspeed
Take it back. You paid for for a brake job without the vibrations. They'll probably try some brake cleaner and if it persists, they'll probably turn the rotor in a lathe to clean it up.
It's back at the repair shop today and we went for a drive and first thing they said that it may be a bushing? But they would pull it in and look at it. He did ask if the car has ever been in a drive thru car wash because he has seen warp rotors happen that way. Pulling into them and the brakes being hot and the water cooling them off could cause this?? But my car has never been in the drive thru wash. Thanks for your help, your answer sounds more professional than what I'm hearing this morning. Thanks
Old 01-02-2014, 07:00 AM
Whit1234's Avatar
Just said its 2 bushing. Also he said the New Audi brakes catch more and that is why I'm having this problem? Thanks
Old 01-02-2014, 07:04 AM
Whit1234's Avatar
Originally Posted by Just Me
Did this occur immediately or come on slowly over a period of time? I have never seen warped rotors, even after race track use. OTOH, i have seen pad deposits all the time, btu they come on slowly. In any event, take it back. What pads were used? Grant
This happen about a few days to a week after getting brakes done. The repair shop said that it's 2 bushings and wasn't the brakes. We used all Audi. He did say the new Audi brakes are more catching and that could be what I'm feeling. Thanks.
Old 01-02-2014, 04:47 PM
Just Me's Avatar
Default warped going through car wash?
not likely, unless the brakes were stupidly hit and there was no line at the car wash (for them to cool).
I dont see how bushings alone would cause the vibration. they could make a brake vibration worse,...
Old 01-02-2014, 04:48 PM
Just Me's Avatar
catch more? That means....
And if they mean "has a higher coefficient of friction" that is not correct.
G
Old 10-28-2014, 11:54 AM
shammy147's Avatar
i have a 2004 a4 got a rattle on front left at any speed rattling on brakes same side when applying gently but dissappears when applying brake firmly do you think this could be a warped disc i have had new pads / track rod end and just bought new caliper which was going to fit tomorrow
DeerHunter
S6 (C7 Platform) Discussion
71
02-20-2024 03:29 AM
alin.zalau
Q7 MK 1 Discussion
09-12-2015 01:09 PM
pattonfrench
A6 (C7 Platform) Discussion
09-07-2015 01:11 PM
stormchaser1967
09-02-2015 09:26 AM
Quick Reply: Vibration when applying brakes
