Go Back   AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 > Q5/SQ5 Discussion
Q5/SQ5 Discussion Discussion forum for the Audi Q5 SUV
Sponsored by: Audi
Old 12-25-2013, 04:59 PM   #1
Coolieman1220
Account #: 167682
Default TDI Long Cranking on Cold Start?
Hey guys, just picked up my 2014 TDI. Had it for two days now, I'll post a review and some pics later.
Today, it is cold here, in the teens to twenties. When I went to cold start the car twice, I pushed the start button, the glow plug lit up, turned off, paused and then the engine went to turn over but it cranked for a good 3 seconds or so before it came to life. Has this happened to anyone else? Is this normal?
I'm going to try putting the engine in the on position first for a few seconds and then start it to see if it still does this. This way the glow plugs will be hot and so will the fuel heaters.
I have heard of this happening with some people on the 335d (never happened to me). On cold days, she just lights up the glow plug light for a second or two and then starts right up.
09' Audi Q5 3.2 Premium + (Lease Return) 12' Audi Q5 2.0t Premium + 14' Audi Q5 TDi S-Line
09' Ducati Mosnter 696 (Upgraded to) 12' Ducati Monster 796
2013 BMW S1000rr
2010 BMW 335d
2010 VW Jetta TDI
Coolieman1220 is offline   Reply With Quote
Old 12-25-2013, 06:06 PM   #2
MP4.2+6.0
Senior Member
Account #: 26081
Default Actually, TDI cold starting time a question of interest for me too.
What is a typical time to start on a modern TDI in cold weather from the point you hit the start button to get things going? How long are the glow plugs doing their thing before the engine turns over? Thus at temps like 0-20F or lower, or well under 0C.
For the OP, in early diesel days it was dozens of seconds, so I expect a few seconds here or there is relatively minor. But since I have a place in Tahoe that can easily be at these temps many evenings or early mornings (or even -10 to -15F at times), I'm curious about the actual field experience in Audi's current USA related TDI motor. Too warm here in the coastal SF Bay Area to have anyone around w/ practical experience in serious cold locally.
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here.
Current #2: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery 7/2013 (pictured at Ingolstadt)
Prior (each modded): 2000 C5 A6 4.2 & '96 C4 A6 2.8Q, both still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS
helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
MP4.2+6.0 is offline   Reply With Quote
Old 12-25-2013, 08:21 PM   #3
DennisMitchell
Account #: 26005
I am on Long Island (near NYC) and it was in the 20's F today. I had 2 second delay on start after pressing button. Slightly longer than in warmer temps. Fwiw.
2014 Q5 TDI (Prem+,Cuvee Silver,Pistachio Beige,Layered Oak,Nav+,B&O,Side Assist,Rear airbags,Hitch)Delivered 10/11/2013
http://forums.audiworld.com/showpost...4&postcount=22
2011 A4 2.0T (Ice Silver,Gray interior,Nav,B&O)
2010 Q5 3.2 (Quartz Metallic,gray interior,Nav)- Traded in
2005 A6 3.2 P+ (lease end)
2001 A6 2.8 P+ (lease end)
DennisMitchell is offline   Reply With Quote
Old 12-26-2013, 03:58 AM   #4
soonerfan
Account #: 88945
soonerfan's Avatar
20's here in Tulsa and I have a similar experience to Dennis.....and my Q is parked in my garage. I have noticed that it takes some time for the engine temp to get off the cold mark. Heater works well in advance of the needle climb. No worries.
2014 Q5 TDI Ibis White/Black
S-Line Plus Pkg., Sport Pkg,. MMI Nav Plus, B&O, Side Assist, Tow Hitch, Protection Pkg.
Gone but not forgotten: 2011 Q5 P+ 2.0TFSI
soonerfan is offline   Reply With Quote
Old 12-26-2013, 04:57 AM   #5
Loafer123
Account #: 162125
I am located in NW Maine, near the Canadian border. We have had minus 20F temps and has routinely been in the single digits and teens of late; the delay in start with our TDI has been 1-3 seconds (closer to 3 seconds in the sub zero temps).
2014 Q5 TDI Prem Plus
2011 A4 Prem Plus w/NAV 6MT
Loafer123 is offline   Reply With Quote
Old 12-26-2013, 05:38 AM   #6
Coolieman1220
Account #: 167682
Are your cars just taking a while to begin cranking because the glow plugs are doing their thing or is the engine cranking for a few seconds before starting up? This only happens on cold starts. I find the engine warms up very quickly.
What should happen, press start button, glow plug illuminates, turns off and then the engine cranks and starts right up. What's happening to me, the glow plugs do their thing for a second or two and then the engine starts to crank and cranks for a few seconds before firing up.
2013 BMW S1000rr
2010 BMW 335d
2010 VW Jetta TDI
Old 12-26-2013, 05:53 AM   #7
spijun
Account #: 184703
spijun's Avatar
It is normal for the TDI engines from the VW Group.
Glow plugs for the first time to launch 2-3 seconds when you open the driver's door, without contact and starting the engine
Q5 2.0 TFSI,S-tronic,
Milano leather, B&O, 19" 5-arm polished
Excuse me for my English
spijun is offline   Reply With Quote
Old 12-26-2013, 06:17 AM   #8
soonerfan
Account #: 88945
soonerfan's Avatar
My engine fires almost immediately with no cranking....and I do sit at idle for 30 to 40 seconds before I slip it into reverse and back out of the garage.
Old 12-26-2013, 10:37 AM   #9
DennisMitchell
Account #: 26005
To clarify, I press the start button (foot on brake), 2-3 seconds pass, car cranks and starts instantly. There is no prolonged cranking.
Old 12-26-2013, 12:57 PM   #10
brutus23079
Account #: 59486
Fired mine up at -2 degrees F. Glow plugs took a few seconds (as one would expect/hope) and it fired right up. No lengthy cranking at all.
2014 Scuba Blue Q5 TDI
Factory hitch
brutus23079 is offline   Reply With Quote
2000, 2006, 2009, audi, cold, diesel, engines, glow, jetta, plug, start, starting, tdi, weather, wont
Forum Jump
