Oil Temperature Switch
Old 12-24-2013, 07:30 AM
tommyleea's Avatar
Default Oil Temperature Switch
Can someone tell me the location of the oil temperature switch on a 2000 A4 2.8 30v engine? I thought it was on the bottom of the oil pan, but that appears to be the oil level sender. My temp isn't working, so I would like to replace the switch. I haven't been able to locate it in the Bentley manual. Thanks
TommyJ
Old 12-24-2013, 09:06 AM
AudiMick's Avatar
TommyJ
It's not a switch , it's a sensor.
I believe it's behind the timing belt on a V6, kind of a PITA.
Item 19 in pic
https://forums.audiworld.com/attachm...1&d=1374079167
Old 12-24-2013, 02:24 PM
twentysevenlitres's Avatar
I think you can get at that from behind the front engine cover, at least on a 12V.
May not be such a PITA - maybe ;-)
Old 12-25-2013, 07:22 AM
tommyleea's Avatar
I am at the timing belt now, so I will check it out.
Thanks to all.
Old 12-25-2013, 04:55 PM
tommyleea's Avatar
Thanks to all.
Well, I didn't see any sensors under the timing cover. There is a connector on the front of the driver side valve cover, but it doesn't look like a temperature sensor.
eggsngrits
12-08-2021 06:58 PM
iowaan
18
12-30-2017 07:56 AM
Jan_PL_S6
12
11-27-2015 07:27 AM
sszyma
Q5/SQ5 MKI (8R) Discussion
19
09-14-2015 11:36 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
Quick Reply: Oil Temperature Switch
