Audi A8 2004 Adapter wiring harness for airbag
Old 12-22-2013, 10:29 AM
gerhardhomes's Avatar
Default Audi A8 2004 Adapter wiring harness for airbag
Airbag light on. Was diagnosed by dealer that passenger seat needs repair kit installed, 5K0998582. A few short wires
Question: anyone has done this and can help me locate where the wires go? Do i need to open up the passenger seat in the back, site ???
Old 12-22-2013, 10:44 AM
mishar's Avatar
Welcome!
Al wires goes to the bottom of the seat. Check there for a yellow airbag harness. Apply some DeoxIT or similar to contacts.
Old 12-22-2013, 07:03 PM
MP4.2+6.0's Avatar
Default Search... (plus more)
It's in the archives. I was just looking at this last night (didn't apply to mine, which currently has an issue with the main bag on the steering wheel).
There are two connectors generally. One is under the seat--just look under there and you will see it (same w/ driver's seat). You are looking for a yellow connector, which the airbag ones are generally color coded. There is another one up in the seat back near the bag unit itself. There is a TSB (technical service bulletin) on this, which reviews the procedure. It deals with the connector down by the floor. That's where the issue usually is, which makes it easier to get at. The crux of it is just re-splicing those wires at the connector area.
Before you do a whole bunch though, try something simple--just unplug and then reconnect the connector under the seat. With the car turned off of course. See if that does it. Many just fiddle with the connectors or apply some anti oxidant stuff (like DeOxIt) and find that cures it.
Old 12-22-2013, 07:17 PM
mishar's Avatar
After that you have to clear code with VCDS. It won't go off by itself.
Old 09-09-2022, 01:51 PM
Flyttxo's Avatar
do you have to disconnect the battery before unplugging yellow airbag plugs?
Old 09-09-2022, 05:09 PM
aTOMic's Avatar
No. Probably not. Keep us posted.
Old 09-10-2022, 07:13 AM
MP4.2+6.0's Avatar
Let's see, I can take a chance with an explosive device, or I can do it by the book. Have at it. Darwin wins.
bballfreak
9
04-14-2019 06:59 PM
Kerry G
05-18-2018 06:12 AM
anordin2
02-08-2017 11:07 AM
joshA4
10-11-2015 02:43 AM
joshA4
09-29-2015 03:58 AM
Quick Reply: Audi A8 2004 Adapter wiring harness for airbag
