Start Button Issue
Old 12-18-2013, 03:53 PM
S4thrills's Avatar
Default Start Button Issue
Any of you had this happen to your start button? Basically, the metal edge of the N pulled up and cut my finger the other day. I had to snap it off so I didn't keep catching my finger.
The start button on our RS5 is a totally different kind and looks like this could not happen to it.
Just wondering if it's happened to others.
Old 12-18-2013, 04:18 PM
nobbyv's Avatar
Wow! No sign of that here. Literally cut your finger? I would have thought the button was molded plastic with a "metal" paint applied. But clearly not...
Old 12-18-2013, 04:23 PM
S4thrills's Avatar
Yes, cut with blood. The button is plastic underneath and aluminum clad (likely just glued to the plastic).
Old 12-18-2013, 05:06 PM
Moribach's Avatar
Happened on my 2010 B8 S4 too....
Old 12-18-2013, 06:36 PM
tenspeed's Avatar
It has happened before but there hasn't been a thread about it in a while. IIRC the center of the "A" was popping up. Some people installed some paint protection film over the button.
Old 12-18-2013, 08:37 PM
S4thrills's Avatar
Will the dealer replace under warranty?
Old 12-19-2013, 03:25 AM
txtony's Avatar
Yes dealer will replace under warranty
Old 12-19-2013, 04:53 AM
mik34's Avatar
Happened to me on my B8 S5. Like others said, dealer took care of it.
Old 12-19-2013, 09:06 AM
Brooklyn's Avatar
Happened on my S4 when a detailer wiped it down. Stuff can get trapped under the letters, and apparently the N in particular. Only solution once that happens is to replace it. Dealer did mine since (a) it was under warranty, and (b) I was using their detailer. Covering it with paint protection film or even something like the COTS phone screens would certainly prevent it from happening, although I worry about the adhesive causing the same problem if/when you decide to remove the film.
Old 12-19-2013, 09:11 AM
S4thrills's Avatar
It's interesting to look at the button on our RS5. Feels way more solid and not prone to this happening. Not sure why they would be different.
Quick Reply: Start Button Issue
