VCDS Programming Question
Old 12-14-2013, 11:48 AM
mariusstrom's Avatar
Default VCDS Programming Question
Howdy all - My Ross-Tech VCDS cable arrived yesterday, and I spent a few hours this morning playing with stuff on the '14 Q5 TDI.
An Auto-Scan of the car was the first thing I did to snag all the info about it. During the scan I got a bit freaked out, as some of the motors in electrical components started actuating (or at least that's what it sounded like), but everything seems normal so I guess that's normal behavior.
I got a bunch of things I wanted programmed, but VCDS threw an error when I tried to program the Gear Selection Display in DIS - basically, it threw an error saying I needed to provide a WorkShop Code and a few other things.
Is it OK to accept the default values of these things, or do I risk goofing anything up here? I figured I'd check here in the Q5 forum as I'm guessing this is car-specific.
Old 12-14-2013, 12:59 PM
spijun's Avatar
Here you have
http://www.audienthusiasts.com/VagCom.html
http://www.audizine.com/forum/showth...-complete-list
http://www.audigh.com/vag-com
http://a6retrofit.tripod.com/articles/a5vagcodes.html
The best for me,in German but Chrome with a translator
http://www.stemei.de/pages/coding/audi-q5-8r.php
Old 12-15-2013, 05:57 PM
Thanks, I've read nearly all of those. I know what the right coding is for the Gear Selection display, I'm just wondering what I should specify for the WorkShop Code (WSC) and the other items it prompts you with. None of the sites above mention this.
Old 12-15-2013, 10:09 PM
spijun's Avatar
It's a new way protect from Audi. In the future, all the more that you used in new models
There is unofficial information that it will Audi in the future completely disable access to the coding
Old 12-16-2013, 06:13 AM
Jubz's Avatar
I've attached a PDF of the various codes I've found on the aforementioned websites; for your hardcopy convenience.
File Type: pdf
Old 12-16-2013, 06:28 AM
spijun's Avatar
Yes, but many of these codes do not function on MY2013-2014 in this is a problem
https://www.audiworld.com/forums/sho....php?t=2856679
Different modules, different coding, access protection
Old 12-16-2013, 09:37 AM
Bob Petruska's Avatar
Default VCDS should promt you with the WSC and use it...
The WSC has been required for many years with VCDS. I used it since my 1997 A4, it is not something new.
On my US 2014 Q5 2.0T , I have coded the following....
1. Gear selection indicator
2. Eliminate DRL wink with turn signals
3. Eliminate rear wiper wipe in reverse
4. Turned off rain sensing wipers
5. Turned on passenger outside mirror tilt on reverse (I don't have that option package)
6. Fogs on with hi-beam
7. Minimum radio volume on start up
I haven't come across any coding that hasn't worked, but obviously from list above I haven't done everything.
Drongo
TT (Mk1) Discussion
20
04-10-2024 06:54 AM
davidbod
Q7 MK 1 Discussion
36
07-25-2022 07:57 PM
eggsngrits
12-08-2021 06:58 PM
Aman Singh Parhar
09-16-2015 06:01 AM
raiderrider
12
09-08-2015 05:46 AM
Quick Reply: VCDS Programming Question
