Hard knocking from 1.8T AEB
Old 12-14-2013, 10:01 AM
tonsa92's Avatar
Default Hard knocking from 1.8T AEB
Let me tell this little story from the beginning...
One week i got my car from timing belt change (also other belts and tensioners and oil + filter), it was working like charm. Later same night car started to tick.
5 Days later when i was on way to work it started to run with 3 pistons only. I changed spark plugs to NGK Platinum plugs, one plug was missing this "bend" that comes over the spike. I started it and YES! ticking sound was gone.
Later i was going to see my friends, i got 200 meters from home and again running with 3, then it shutdown completely. I waited for a while and started the engine, it ran with three pistons and i tried to drive it to home. Suddenly it started to make really loud knocking and i shut the engine.
It was towed to workshop. One broken/stuck lifter was found and replaced it (how do you call it when things kinda weld together?).
Still same sound but runs fine with 4 cylinders now.
Today oil pan was open but no loose on connecting rod bearings was found.
It's been there now a month. I really would like to get it back to road.
Here is sound sample from it:
http://tinypic.com/player.php?v=j5h2...5#.UqyqgfTd_Z9
I got no good answers from finnish Audifinns forum, so i tried from here.
Old 12-14-2013, 01:29 PM
Head Cat Herder
Kris Hansen's Avatar
oh that does not sound good at all.. I'd first double check the timing belt - Make absolutely sure it's correct at Top Dead Center (TDC) for the cams and the crank.
Old 12-15-2013, 04:20 AM
tonsa92's Avatar
Timing has been checked three times already It's as close as it can be
EDIT. Does anybody have somekind of xray photo of these oil tunnels? I could check if these have somekind of garbage in it.
Old 12-17-2013, 09:24 AM
tonsa92's Avatar
Cylinder head was disassembled from the motor. This broken spark plug bend was between piston and cylinder head. So i think we finally found the problem!
Old 12-17-2013, 12:47 PM
Head Cat Herder
Yikes.. Well, glad you figured it out, and that it wasn't a mangled valve!
Old 12-23-2013, 10:37 PM
tonsa92's Avatar
Yes, all valves was straight and ok!
vansoffyomama
TT (Mk1) Discussion
09-28-2015 04:38 PM
mxp
09-26-2015 10:15 AM
legerrej
09-25-2015 08:43 PM
ECS Tuning-Audi
09-25-2015 01:20 PM
ECS Tuning-Audi
09-25-2015 11:51 AM
Quick Reply: Hard knocking from 1.8T AEB
