optical bus problem
Old 12-13-2013, 02:15 PM
life4sk8's Avatar
Default optical bus problem
Hi everyone,
Since last week, my MMI was acting weird.. No sound but screen or nothing except for the boot screen for 15 second and after that, nothing. I start digging for a solution: all fuse are good, check with vag-com this is what I've got:
Chassis Type: 4F (4F0)
Mileage: 197770km/122888miles
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 731 B HW: 4E0 035 729
Component: Interfacebox H43 1190
Revision: 00000000 Serial number: 303CC067520290
Coding: 0000003
Shop #: WSC 02335 785 00200
VCID: 21490A57F8801016BBD-8074
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H08 0050
Subsystem 2 - Serial number: 00000000383558
Subsystem 3 - Serial number: 0104.04.060000000100010835ÿ
Subsystem 4 - Serial number: 010835ÿ
2 Faults Found:
01964 - Control Module for Seat & Steering Column Memory (J136)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 3
Reset counter: 58
Mileage: 197774 km
Time Indication: 0
Date: 2013.12.12
Time: 10:25:07
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 19
Reset counter: 39
Time Indication: 1
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H11 0070
Revision: 11 Serial number: 13008063318082
Coding: ECFE73CC1B7104
Shop #: WSC 02334 785 00200
VCID: 275D144F96A4EE26F59-8072
2 Faults Found:
00463 - Control Module for Digital Sound Package (J525)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 2
Reset counter: 45
Mileage: 197058 km
Time Indication: 0
Date: 2013.12.05
Time: 10:40:53
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Mileage: 197677 km
Time Indication: 0
Date: 2013.12.11
Time: 15:43:33
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 A HW: 4F0 035 223 A
Component: DSP-High C6 H09 0140
Revision: PROD_01 Serial number: 00000000207246
Coding: 0000126
Shop #: WSC 02323 785 00200
VCID: 1C373BA3DFE23DFE68B-8049
1 Fault Found:
00876 - Treble Speaker Rear Left (R14)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00111100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 57
Time Indication: 0
Optical Bus Diagnostic : Standard
Control Module Part Number: 4F0 910 468 A
Component and/or Version: Gateway H11 0070
Controller Electrical Optical
19-CAN Gateway OK OK
07-Control Head(High/D3) OK OK
0E-Media Player 1 OK OK
77-Telephone OK OK
47-Sound System OK OK
67-Voice Control OK OK
56-Radio OK OK
37-Navigation OK OK
Today, I drop the glove box to see if everything was fine around the gateway and the control head and I remove the amp and all the support that hold the radio and the navigation dvd to check if everything was good there. I found the rear windows washer pipe broken with a big stain on the trim around the speaker so I fix everything. Ran an other test to see if everything was ok and this is the result:
77-Telephone OK OK
47-Sound System OK ERROR
56-Radio OK OK
37-Navigation OK OK
Did I broke one optic cable??? How can I know if an optic cable is broken? I plug everything back as it was. If I broke one optic cable, how can we fix it? And for the codes it is worst:
07-Control Head -- Status: Cannot be reached 1100
0E-Media Player 1 -- Status: Cannot be reached 1100
19-CAN Gateway -- Status: Malfunction 0010
37-Navigation -- Status: Cannot be reached 1100
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Cannot be reached 1100
4F-Centr. Electr. II -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
67-Voice Control -- Status: Cannot be reached 1100
77-Telephone -- Status: Cannot be reached 1100
I'm pretty sure the issue start with the broken rear window washer pipe but now this is fix, how can I fix the other issue. Please I need your help.
Thanks
Old 12-18-2013, 04:34 PM
eazy211187's Avatar
If the holes broke from the rear window then it sound like your Amp is fryed.
Buy one on ebay and take to the dealer to reprogram.
Old 08-27-2017, 02:35 PM
Absi Amri's Avatar
Hi .. it looks I'm browsing in historical threads... but I had the same problem with MMI in my Q7 - 2007. Exactly what you have described with the same error code (00384 - Optical data bus, open circuit). May you kindly (if you still remember): tell me how it ended, and what was the solution
accept regards
Old 07-07-2020, 06:19 PM
Samer Samy's Avatar
Default Hi
accept regards
did you reach a solution?
Old 07-07-2020, 09:24 PM
kelisko's Avatar
Watch this: youtube.com/watch?v=ID4_W2BnIu8
Yammyhaha
A6 (C7 Platform) Discussion
05-31-2021 05:52 PM
Nish
S6 (C7 Platform) Discussion
09-14-2015 10:02 AM
bradaudi
9
09-10-2015 02:26 PM
gagethrash
Q5/SQ5 MKI (8R) Discussion
09-08-2015 07:11 PM
NJ-DUCATI
09-08-2015 05:05 AM
Quick Reply: optical bus problem
