Service light - 2007 S8
Old 12-11-2013, 11:08 AM
ninefourteener's Avatar
Default Service light - 2007 S8
Yes.... I've searched, and I apologize in advance for my ignorance..... but I've received a lot of conflicting information:
1) the dealer has to do it
2) you need a special tool
3) push and hold the odometer button
4) complete above.... and then turn the key
5) say "abracadabra", spin twice, and play barry manilow backwards.
Not sure what to think. I've had the car about 8k miles (about to turn 80k on the clock)... I plan on doing the oil this weekend. I just want to get educated on how to turn off this warning... or it will drive me crazy.
By the way.... this isn't a check engine light.... just the normal "Service!" Warning that displays for a moment after startup... and then goes away.
Old 12-11-2013, 11:20 AM
Jake Musser's Avatar
in for info
Old 12-11-2013, 11:26 AM
Originally Posted by Jake Musser
in for info
??? I'm afraid I dont understand what you mean. Sorry. Please explain
Old 12-11-2013, 11:27 AM
Im in this thread, for into as well. Same problem
Old 12-11-2013, 11:28 AM
MN-A8's Avatar
I believe the service interval needs to be reset with vag-com, or by a dealer. I'm not sure if there is a special process by pushing a few buttons to turn it off on the A8/S8 models.
I have a Vag-com and have played with the services myself, not too familiar with the system but it didn't resolve it.
Old 12-11-2013, 11:32 AM
MP4.2+6.0's Avatar
Default 1 and/or 2
Either the dealer or someone with VAG-COM/VCDS or equivalent system/software. Presumably many indy mechanics who deal with later model VW's and Audis will have this, and most of us serious DIY'ers buy the VAG COM cable over time.
Unusually among later Audi's I owned, you could turn off the service interval display with the push the button stuff on the millennium era C5 A6. Probably meant the older D2 A8 as well. But on the D3, you need the tool/equipment.
And to be clear, I mean the service interval message stuff, not the check engine light (CEL). The latter often needs the same tool/equipment, unless it is a minor issue that in the OBDII coding world is permitted to self clear after a counted number of successful running cycles with no evidence of an issue.
Old 12-11-2013, 11:37 AM
jakematic's Avatar
Default +1 and procedure
SRI procedure: http://wiki.ross-tech.com/wiki/index...eset_Procedure
This is the final solution to all issues when everything else fails
Old 12-11-2013, 11:57 AM
Thanks folks. I'm going to pick up one of those VCDS cables and the necessary software. I'm sure ross-tech is likely the best available product..... but for my purposes.. I found one for about $80.
Also need to pick up a set of plugs.... and the suction pump for a topside oil change. That'lL be a first for me as well.
Old 12-11-2013, 12:09 PM
tx170754's Avatar
It can only be done using the VCDS or the dealer, not so sure if the "$80" one will do it.
Quick Reply: Service light - 2007 S8
