Suspension Settings on MMI - missing.
Old 12-06-2013, 12:40 AM
A200_10V's Avatar
Default Suspension Settings on MMI - missing.
Hi all,
The "CAR" button wonīt show the suspension setting options on the MMI.
Itīs an A8 D3, 2003.
Adaptive Air Suspension - Sport (2MA)
I have VCDS but donīt know how to activate the menu. Have seen some threads saying that:
- Go to the [07-Control head] module.
- Go to Adaptation.
And then??? Which channell and what new value to put in?
Iīve checked the Gateway > Installed List and if Leveling Module is checked. It is!
Help is MUCH appreciated!!
Old 12-06-2013, 07:21 AM
Limoncello's Avatar
Originally Posted by A200_10V
Hi all,
- Go to Adaptation.
as i said in the other thread its easier to use vcds to activate your hidden menu and do it from there.
hiden menu activation is here
http://www.audi-resource.com/mmiaccess.php
Old 12-08-2013, 07:50 AM
A200_10V's Avatar
Thanks for answering!
I have the hidden menu activatet, but nothing activates when I check the air suspension box and accept changes.
Furthermore, I have the Sport Suspension PLUS menu showing with the choices Comfort - Dynamic - Sport. But all greyed out. This appeared when I went into [07] => adaptation => channel 1 => entered new value: 64. Before that there was no suspension menu showing at all.
Thought that I have to use VCDS to get the right menu to start with... I donīt know where to go from here actually...
Old 12-08-2013, 08:05 AM
Limoncello's Avatar
so youve done both of these
Car Menu Maske > Car View options >
there is an option called Air Suspension, should be checked
plus the vcds 07 adaption
do you have any scan errors on vcds?
Old 12-08-2013, 08:14 AM
Limoncello's Avatar
oh just remembered the menu will appear and be greyed out - you need to physically reboot the MMI for it to work, not just turn it on and off
Old 12-08-2013, 08:33 AM
A200_10V's Avatar
Iīve done the VCDS 07 adaptation channel 8 - new value 1. Iīve checked the Air Suspension option in Car View Options. There are no fault codes AND I have rebooted the MMI tel+big ****+upper right...
Still, something must be wrong since I donīt have the "Air Suspension - Sport" menu showing. Instead I have the Sport Suspension Plus...
Do you know which value to put in 07 adaptation Channel 1?
Old 12-08-2013, 08:42 AM
A200_10V's Avatar
Oh, my bad! When I go into Car View Options and Air Suspension, there are a number of options attached to this choice (all greyed out and no possibility to change). The one that is checked sais v>v_thr. Some of the other options are: "default", "kl15 aus", "Stillstand", "Disclaimer", kl15+vv, kl15+ss and similar...
Old 12-08-2013, 08:54 AM
Limoncello's Avatar
im not sure which menu you are expecting, the one you describe is the only one i know of. have you seen something different?
Old 12-08-2013, 08:58 AM
mishar's Avatar
Hidden Manu > APG... > Air Suspension should be checked too.
Do you have Lift option on that Suspension Menu?
Old 12-08-2013, 09:28 AM
A200_10V's Avatar
Okey, Iīm trying to attach some pics...
Quick Reply: Suspension Settings on MMI - missing.
