2000 A6 Avant - Cold Heat?
Old 12-02-2013, 09:50 AM
718Driver's Avatar
Default 2000 A6 Avant - Cold Heat?
Hey guys -
Question I'm hoping you might be able to help with. I've got a 2000 A6 Avant. The heat is blowing lukeworm. I can fiddle with the settings and get it blow hot for a sec, but then it switches over and blows lukewarm at best. Weird. Would appear that the heat is getting generated, but can't get it to blow hot out of the vents. Wondering if it's the Heater Control Valve? Anyone with experience on this - would be appreacited. If it is the heater control valve - is it difficult to replace myself? Thanks again.
T.
Old 12-02-2013, 12:22 PM
SloopJohnB@mac.com's Avatar
Originally Posted by 718Driver
Hey guys -
T.
Use vag-com to check the hvac control system.
Old 12-02-2013, 06:00 PM
GTA_Driver's Avatar
Could even be faulty thermometer in the climate unit, reporting the air is hotter than it is. So the automatic climate unit adjusts the temperature to colder.
Vag-com would be helpful here.
Old 12-03-2013, 02:49 AM
Tech Guru
4Driver4's Avatar
Bleed the air out of the system.
What work was done since the heat last worked?
Vivian
10-11-1999 07:37 PM
Garry
10-08-1999 08:00 PM
toms
09-14-1999 02:34 PM
Mike Hirsch
07-16-1999 12:29 PM
Quick Reply: 2000 A6 Avant - Cold Heat?
