Parking Light Wiring
Old 11-11-2013, 08:05 PM
rogmac1175's Avatar
Default Parking Light Wiring
Hello all. Sorry if this is the wrong place but I need some help. I have a 2004 A6 with Factory HID headlights. I bought aftermarket LED DRL's and have them all hooked up with the exception of the lead to the parking light. My mechanic ran the wire but won't make the connection or tell me how for liability reasons. Can anyone tell me what wire behind the headlight/park light is the hot lead for the parking light that I need to tap into??
Old 11-12-2013, 11:28 AM
AudiWorld Expert
Reggie's Avatar
Why would you need a new wire? The LED DRL should be a direct replacement for the incandescent bulb.
Bentley sells manuals that have the wiring diagrams
Old 11-12-2013, 11:57 AM
SloopJohnB@mac.com's Avatar
You need to probe the wires to find the one that is hot when you need it hot.
Normal DRL operation is when the engine is on yet turn off when one or the other turn signals is on. Hooking the DRL up to a parking light is a kludge that you may live with…the DRL will remain lit when you use the turn signal(s).
Old 11-12-2013, 01:14 PM
rogmac1175's Avatar
This is an aftermarket LED kit. It doesn't replace the incandescent. It's an add-on. The instructions say to use a parking light so that the lights dim when the headlights are turned on. Anyone have any idea where to even start? I pulled the parking light out and there aren't even wires going to it...it's just a plastic bracket that unsnaps
I'm lost...this should've been a pro job to begin with.
Old 11-12-2013, 02:21 PM
OGBULLYLOCDAWG's Avatar
Ooh, LED DRL's as in fog lights. I got confused initially thinking that you were replacing the incandescent bulbs with individual LEDs.
If you want access to the parking light wiring without taking off the headlight lens, you will have to remove the bulb cover on the back and find the three wires leading towards the parking light.
I'm not sure if your '04 facelift wiring is the same as my '01 pre-facelift, but for me brown is ground, red is for the turn signal and green is for the parking light.
larryincmh
06-26-2009 07:46 AM
[Arawan]
05-30-2006 11:01 AM
TTTEXAN
TT (Mk1) Discussion
05-04-2004 03:29 AM
benk
07-24-2003 01:34 PM
GDA4
06-05-2001 09:02 AM
Quick Reply: Parking Light Wiring
