Worn Front Snub Mount?
Old 11-08-2013, 05:34 PM
mill3241's Avatar
Default Worn Front Snub Mount?
What are the signs of a worn snub mount? (I think thats what the rubber bushing on the front of the engine is called) I was under my car today and noticed mine has cracks in it. 2005 3.2 engine, about 80k miles.
Old 11-08-2013, 07:34 PM
dzywicki's Avatar
I have the same thing on mine (2005 3.2 with ~72k miles). Looks pretty easy to replace, just wasn't sure what was normal and what the effects of it being worn would be.
Old 11-11-2013, 12:05 PM
haloguy628's Avatar
Snub mount is a damper that restricts movement of the engine due to torsional forces.
I would not bother replacing it unless the snub mount splits completely. The snub mount is shaped similar to mushroom and what you are seeing in the picture is the stem. The hat is inside and most likely intact, otherwise you would have serious vibration when stopped and in gear.
Jesster
12-09-2004 11:15 AM
sloth-fratelli
11-16-2004 11:40 AM
GDA4
08-19-2004 06:32 AM
Adam Mowafy
04-04-2004 04:30 PM
squrlathon
12-09-2002 08:57 AM
Quick Reply: Worn Front Snub Mount?
