speedometer stopped working....WTF
Old 10-04-2013, 07:00 PM
jimmyjames72's Avatar
Default speedometer stopped working....WTF
2004 Audi A6 2.7t quattro automatic..161,000 miles...the speedometer stopped and i ran codes and it said VSS , replaced and it still doesnt work...its so weird cause it will jump around one minute and then stay stuck on 0, then it may work for 30 minutes then stop again.....what the hell can it be?
Old 10-04-2013, 07:48 PM
tester123's Avatar
possible intermittent wiring / loose contact issues..?
Old 10-04-2013, 08:00 PM
loose contact wires where?
Old 10-05-2013, 12:49 AM
nzaudia6's Avatar
Is every other gauge and light in the cluster functioning properly? I had a B5 A4 that had a flickering speedo needle. It got worse and worse and eventually stopped altogether. When the headlights were turned on the dash went completely dead and the all illuminated buttons on the interior went off e.g window buttons etc. I had to replace the dash to fix that problem
Old 10-05-2013, 06:00 AM
everything works fine except the speedo and then in turnmesses up the gas gauge and the odometer also.....what can this be...before i have to go to audi dealer.....
Old 10-05-2013, 07:36 AM
tester123's Avatar
from vss and possibly behind the instrument cluster... Scanned to see any codes?
Old 10-05-2013, 08:15 AM
yeah the code it ran was calling for the VSS to be changed...i changed that and it still didnt work....some said the cluster has to be changed...but there is something like an imobilizer associated with that.
Old 10-05-2013, 09:39 AM
Prospeeder's Avatar
The instrument cluster gets the VSS signal, then sends it to the ECU which will set a code. It is not getting VSS, because the instrument cluster has failed. Its not uncommon to have the electronic speedometers fail.
Old 10-05-2013, 01:13 PM
so if i have to replace the speedometer cluster, is something you can do yourself? it lookds fairly simple...a few screws in the front and it comes right out..or is this an expensive job for an audi dealer to do?
Old 10-05-2013, 03:17 PM
tester123's Avatar
Just found out in the manual:
The Immobilizer is a theft-deterrent device that adds a layer of security that is standard on every Volkswagen and Audi model. This is achieved with an electronic device embedded in the ignition key, an Immobilizer Control Module and an electronic link to the Engine Control Module.
Working with Immobilizer Systems
Audi limits access to certain functions by requiring a Personal Identification Number (PIN).
PINs are required for the following functions:
• Adding new keys
• Replacing lost keys
• Replacing Instrument clusters
• Replacing Engine Control Modules
• Other repairs to the Immobilizer system
GeKo
Audi uses an on-line Immobilizer Adaptation (PIN) delivery system, known as GeKo. GeKo is a vehicle anti-theft protection system. With this system, the VAS 5051 or VAS 5052 diagnostic tester is connected to the vehicle and via Internet to an online database called Fazit. The identification of the tester and vehicle are passed to the database and the correct PIN is passed to the vehicle in a secure link without direct user interface.
Quick Reply: speedometer stopped working....WTF
