Is there a quick dial or favorites option when using phonebook?
Old 10-01-2013, 12:26 PM
PunjabiM3's Avatar
Default Is there a quick dial or favorites option when using phonebook?
I am curious if there is a method, submenu, whatever to store the number numbers I dial most often so that I do not need to search in the directory every time? I know for example on my wife's car you can store the contacts/numbers you dial most often in a favorites section so this way you can just select and dial. I believe it is the same on BMW. Any help would be appreciated. Thanks!
Old 10-01-2013, 02:06 PM
snagitseven's Avatar
You can pull your "favorite" names into the car's Directory from the phone which is separate from the phone's own directory. Also, you can enter the first few few letters from the MMI to go directly to the names you seek. You can also use the Voice Recognition system to call a named entry.
CtheW0rld
Audi A5 / S5 / RS5 Coupe & Cabrio (B9)
06-04-2018 07:58 AM
perdido34
A4 (B8 Platform) Discussion
01-15-2010 06:46 PM
Andrewaw
09-10-2008 11:34 PM
Excubey
Q7 MK 1 Discussion
10
05-14-2008 05:33 PM
geordie
10-28-2004 04:23 PM
Quick Reply: Is there a quick dial or favorites option when using phonebook?
