Factory Bluetooth Phone Help
Old 10-01-2013, 12:17 PM
kgd_007's Avatar
Default Factory Bluetooth Phone Help
So another question with my "new" car to replace the totalled S8. It is a 2009 S8 and yesterday when I test drove the phone sync'd and worked fine. Today it jumps around different displays when it connects to my iPhone 5 for a call. The display changes screens randomly, the microphone mutes itself for no reason and the audio cuts in and out. I tried resetting the MMI, deleting phones from MMI and the Audi connection on my iPhone and starting over. No luck does the same thing. I did wash the car this morning before this but didn't notice anything wet inside the car.
Any ideas on what I can try or look for?
Thanks,
Kris
Old 10-01-2013, 12:49 PM
MP4.2+6.0's Avatar
Default As always, think phone issue too
One incremental drop among the many a phone takes can do it. Pair it to another known good bluetooth vehicle before even deciding which "end" the problem is on.
Old 10-02-2013, 07:06 AM
kgd_007's Avatar
So the phone worked fine on the way home. There were no fault codes registered for the phone system. Only thing I can think of is that when I washed the car water somehow got near the electronics that relate to the phone module. I guess it could be something else but not sure what that would be.
If a leak caused that, were would I start to look to remedy the problem? Seems odd that a $100k car delivered in 2009 with less than 40,000 miles would be leaking...
Never had an issue with my old car which was a year older.
Old 10-02-2013, 08:56 AM
MP4.2+6.0's Avatar
Default Or once again, maybe your phone is broken???
Why the focus on only the car?
Old 10-02-2013, 09:27 AM
kgd_007's Avatar
Good point. I just assumed the car since the phone worked on the way home. I have never had an issue with the phone, I will try a different phone if it acts up again. I will also do another quick wash of the car to see if that makes it act up again.
Old 10-02-2013, 07:58 PM
mishar's Avatar
Your Bluetooth module is under the drivers carpet. Not the smartest place for electronics, but it is in a plastic case so you need quite a bit of water to flood it. Once flooded, I believe, wont come back. I am not sure what MMI software version you have. Probably the latest, but just in case check it.
everwake
06-01-2014 05:56 PM
kylesmith177
A4 (B7 Platform) Discussion
07-10-2013 11:26 AM
cpotts00
09-13-2012 06:13 AM
GDeen
07-15-2008 02:31 PM
ACEsA6
02-28-2001 10:58 AM
Quick Reply: Factory Bluetooth Phone Help
