Starter motor help need ASAP
Old 10-01-2013, 02:16 AM
Redmask09's Avatar
Default Starter motor help need ASAP
Hello all I've recently got the following a6 allroad 2.5 tdi on a 2001 ...
Now today I've taken the front end off
Alternator is out and I've taken one bolt out the starter motor.... However my problem is the 2nd bolt ...
Has I'm looking at it all I can see is the bolt thread... I've got under the car and can't seem to find a way to get into get the second bolt out....
I really don't want to make more work for self ... How can I get the bolt out from underneath or anyway tbh starter got to come out one way or another..
Thanks very much
Danny
Old 10-01-2013, 03:25 AM
silverd2's Avatar
Thanks very much
Danny
Have never done this job myself. But here's Bentley's procedure on a 2.7T US model...no TDi Allroads over here.
Old 10-01-2013, 03:40 AM
Redmask09's Avatar
hello thank you very much for the photo...
the problem ive got is i cant access the bolt from the transmission side...
the top bolt... has looking at it from front of car all i see is the thread...
i need to no how to get to the bolt from transmission side ?
danny
Old 10-01-2013, 03:54 AM
amiram's Avatar
Default starter (AKE engine 2.5 TDI)
Thanks very much
Danny
Move the lock carrier to the service position end remove the Mechanical fan With two 32 mm wrench, Covers,Alternator Belt and the Alternator, Then you can dismantle the second bolt. (Quoted from ELSA WIN).
Old 10-01-2013, 04:14 AM
amiram's Avatar
Default The first bolt
Thanks very much
Danny
The first bolt: You need to disassemble the Leave rear noise insulation (Underside of the vehicle), Then you see it
Old 10-01-2013, 05:48 AM
Kneale Brownson's Avatar
Thanks very much
Danny
The starter has a through hole for the bolt with the nut on it and a threaded hole for the bolt with the threads, both of which you see from the front. Both get to the starter through the transmission flange. The heads of both bolts are reached from underneath by feeling up along the bell housing. On the AR, you need to have the belly shields removed.
Old 10-01-2013, 06:14 AM
Old_School_Audi's Avatar
The upper bolt is accessed from the transmission side. Remove the right front tire/wheel assembly. Go in through the wheel well opening forward of the axle shaft. Access to the bolt head is very difficult. Sockets didn't work for me. I had to use short wrenches tandemed up to get enough leverage.
All of this is assuming the TDI bellhousing is the same as the 2.7T
Old 10-01-2013, 06:19 AM
Redmask09's Avatar
Thanks everyone...
So if take drivers wheel off I should be able to get to it from that side...
What did you use to get it off ?
Old 10-01-2013, 06:56 AM
A high level of mechanical apptitude and a tool set built up over30yrs.
Seriously, you may have to cut/bend/weld/modify standard wrenches to remove this one bolt. The Bentley does nottell you about the patience and ingenuity needed to work on our Audi's. There is a reason why these cost so much when repairs are needed.
Old 10-03-2013, 01:26 PM
Redmask09's Avatar
Thanks for the advice but I managed to do it with a 16mm and ratchet ?
No need for making tools .....
First bolt access from front of car ...
Second bolt drivers wheel and arch off .. Straight forward access ...
Thanks
ReevesL
2.7T V6 Discussion
06-12-2019 02:17 PM
Redmask09
TDI Discussion
10-01-2013 02:18 AM
theweeze_1
02-28-2010 07:35 PM
Catamount90
12v V6 Discussion
05-07-2007 06:44 AM
TSull
05-17-2006 02:09 PM
Quick Reply: Starter motor help need ASAP
