RS 7 Discussion forum for the Audi RS 7
RS7 versus S8 engine
Old 09-24-2013, 05:19 PM
2012s4's Avatar
Default RS7 versus S8 engine
What are the differences between the two engines?
3.4 seconds versus 3.5 seconds zero to sixty, but the S8 is heavier?
I heard the dual intake of the S8 make the engines on par?
Please she'd some light
Old 09-24-2013, 09:59 PM
DeerHunter's Avatar
All I've ever read is that the RS6/7 make more boost than the S8. Engine and drivetrain are the same, otherwise.
Old 09-29-2013, 04:06 PM
Max audi's Avatar
There's a good discussion on motortrend with Lieberman and the head of audi Quattro division on wide open throttle
Old 10-15-2013, 07:05 PM
MARKNMTT's Avatar
Correct. Few minor things...the discussion mentioned above of the guys in charge of the RS7 program stated clearly the RS7 will indeed be faster than the S8. The 3.5 is sandbagging.
Old 02-01-2014, 12:32 AM
gedis080's Avatar
Coud you please post a link if you can ? I can't find it ...
Found only this one related to RS7 and Lieberman
http://www.motortrend.com/roadtests/...an_comparison/
Old 02-03-2014, 03:27 PM
Kenshin0930's Avatar
The S8 & RS7 share the same engine basically. And I say basically because the housing in the RS7 is very different, and therefore, the biggest change was made to the intake of the Turbos shaping into a V, and much closer to main compartment. In a way many are right - boost pressure goes way up with that much logistics put into it. I'm sure to make it fit, a few things were "tweaked" along the way, but from what I understand, this is more powerful in almost every aspect. It shares the engine put into the Bentley C. GT (with more horsepower & boost). It can take a F40 up to at least 70, and give an R8 a run for its money! It will be a while before we see a lot of these head to heads - ppl still need to break them in!
I leave the floor to the engineers and audi guru's however, I'm just a simple being
hevek
10-09-2018 11:38 PM
rickymp
S6 (C7 Platform) Discussion
12-11-2013 12:32 AM
GermanGarage
A6 (C7 Platform) Discussion
11-07-2012 11:02 AM
btk_1
12-05-2005 02:26 PM
Longwolf (Christian)
08-20-2001 07:01 PM
Quick Reply: RS7 versus S8 engine
