**Help!! I have a burned Navagation DVD...**
Old 09-16-2013, 07:55 PM
A8rick's Avatar
Default **Help!! I have a burned Navagation DVD...**
I burned a navagation dvd on dvd+R dl from a torrent site. I am getting cd unreadable. How am I supposed get this dvd to read in my cd changer in a 2004 Audi A8 to update the navigation map? Please help... Here is the file version I have... "Audi Navigation Plus RNS-E North America 2011-2012"
Old 09-16-2013, 09:10 PM
MP4.2+6.0's Avatar
Default How about: buy a legit one?
Just a thought.
More generally, people often have problems w/ copies, up to and including labels coming off into the DVD player guts if it's an ebay hack job or some such pretending to be the real thing.
Old 09-16-2013, 09:42 PM
mishar's Avatar
Old 09-16-2013, 11:18 PM
DA8
DA8's Avatar
Maybe I am way off base here, but doesn't the navigation DVD go into the navigation DVD reader located in the left rear fender well? I have not done it myself, but I am pretty sure there is a DVD reader in there for navigation and the DVD does not go in the CD changer. That is how my 2005 is I believe.
Old 09-17-2013, 12:37 AM
bigdawg56's Avatar
yes it needs to go in the trunk
Old 09-17-2013, 04:11 AM
Mister Bally's Avatar
If you are installing it in the DVD nav. player in the trunk, buy a legit nav. DVD as there is some encryption that a copy may not have. Or, find someone with an A6 or A8 and test in their car. You could have a bad nav DVD player.
Old 09-17-2013, 04:25 AM
DA8
DA8's Avatar
See Rick, you're trying to put it in the wrong hole!
If you can put it in the right hole and make it work I'd like to know how to get the free version you found. I don't have any need to give Audi another $200.
Rick is pirating in more ways than one.
Old 09-17-2013, 05:03 AM
Brozee's Avatar
RNS-E is your problem. We don't have navigation plus. When you find the right one, burn it at 2.4x on a verbatim DVD+R and you'll be good.
Old 09-17-2013, 07:44 AM
A8rick's Avatar
OK... I see I may have the wrong dvd but, do you know which one I should be looking for, for my particular car? I also saw a reply that there is a dvd reader for the navigation update in the trunk near the right fender well?
Old 09-17-2013, 08:16 AM
ltooz_a6_a8_q7's Avatar
Default Good copy would work...
I made a copy 2010 from A8 DVD nav and put it in my retrofit Q7 DVD and it updated fine after loading the original V6 navigation DVD. Burn and verify with the lowest speed possible.
loading original V6 DVD
update with 2010 DVD nav
Cheers,
Louis
Quick Reply: **Help!! I have a burned Navagation DVD...**
