Go Back   AudiWorld Forums > Audi Models > Audi A4 > A4 (B5 Platform) Discussion
Old 09-14-2013, 02:09 PM   #1
Jim4802
Account #: 243370
Default need help asap. Timing belt job
Hello, I'm 12 hours into my first timing belt job late on a Saturday night. 1998 A4 1.8L engine AEB. I just did the water pump and Therm and I'm putting the WP/PS belt back together and the new belt is very loose? So is the old belt and I can't figure out why. The site i'm following to do the job said it should be tight but mine has a good inch or two of play in it? the old and new belts are the same size and i don't recall when taking it apart how loose the old belt was?? any advise??
Jim4802 is offline   Reply With Quote
Old 09-14-2013, 02:18 PM   #2
Huskerbob
Account #: 219486
Huskerbob's Avatar
Are you talking about the 11 x 528 belt? The shortest one of the 3.
2001 A6 Quattro Avant 2.8l (sold)
2000 A4 Quattro Avant 1.8l t auto
2003 Eddie Bauer Exploder 4.0 4x4
Huskerbob is offline   Reply With Quote
Old 09-14-2013, 03:08 PM   #3
Jim4802
Account #: 243370
Yes, Thats the size I have but it seems very loose. seems I could almost pull it off. I could text you some pics if your familar with how tight they should be?
Old 09-14-2013, 03:15 PM   #4
Huskerbob
Account #: 219486
Huskerbob's Avatar
I just checked mine and it's fairly tight. I just put it on a few weks ago. I'm going to go take another look and see what I see. I'll be back shortly.
You did have to loosen the PS pump to get the old belt off right?
If not let it loose and then use a short lever to pull it tight.
Three bolts I believe. Probably 2 or 3 different heads too
Old 09-14-2013, 03:34 PM   #5
Jim4802
Account #: 243370
I did not lossen the PS pump. I removed the front of the WP pully that splits in half with 3 6mm bolts. I dont see where the PS is adjustable? i have the front off the car and can see everything pretty clearly.
Old 09-14-2013, 03:42 PM   #6
Huskerbob
Account #: 219486
Huskerbob's Avatar
On mine there are 2 bolts on the top and one sort of behind. I had to loosen all 3. I do not recall splitting the WP pulley.
Just took another look and the 3rd bolt is behind the pulley. 2 on the top pivot points.
Old 09-14-2013, 03:58 PM   #7
Jim4802
Account #: 243370
Is your motor the 1.8L AEB?? i just cant see where the PS pump is adjustable? I see all the bolts clearly, but nothing to see how to make the belt tighter? I'll look around on the web some more. Please let me know your engine. much appreciated
Old 09-14-2013, 04:14 PM   #8
Huskerbob
Account #: 219486
Huskerbob's Avatar
Mine is an ATW. Can you snap a photo?
Old 09-14-2013, 05:04 PM   #9
Jim4802
Account #: 243370
the belt and the bolts holding the PS pump. The brace in the bottom is not adjustable. can u see the slack in that belt? I'm just not sure. Hope I can attach pics
Old 09-15-2013, 04:03 AM   #10
Huskerbob
Account #: 219486
Huskerbob's Avatar
I see your answer over at audiforums.com evidently there is a spacer on one of the pulleys that if removed will draw that belt up tight. Good luck.
audiworld, belt, loose, timing
Forum Jump
