Go Back   AudiWorld Forums > Audi Models > Audi Q3 /Q5 / Q7 > Q5/SQ5 Discussion
Q5/SQ5 Discussion Discussion forum for the Audi Q5 SUV
Sponsored by: Audi
Old 09-08-2013, 08:03 PM   #1
Yoshimura
Account #: 221381
Default Suspension - SQ5 versus 3.0T
How does the SQ5 suspension compares to the 3.0T? Does the adaptive suspension make a big difference on the 3.0T?
Yoshimura is offline   Reply With Quote
Old 09-11-2013, 10:41 AM   #2
Mister Spock
Account #: 259141
Mister Spock's Avatar
I feel that the suspension on my 2014 SQ5 is much tighter than the standard suspension in the 2013 Q5 3.0T that I test drove. The SQ5 feels "corvette tight" to me, and you really feel the road much more than the standard model's ride. This is independent of which driving mode you are in, as shock dampening is not a selectable option on my MMI (and I have the Prestige model).
Mister Spock is offline   Reply With Quote
Old 09-11-2013, 12:03 PM   #3
laakness
Account #: 244588
I agree, it's very car like in the turns but obviously has a higher center of gravity.
It's stiff but not overly so. I don't miss the adaptive suspension I had in my S4.
Mine - 2014 SQ5 Premium Plus | Phantom Black | Black Nappa | B&O | Nav | 21" Wheels | Side Assist
Wife - 2009 A4 | 3.2 V6 Prestige | Ibis White
Previous - 2013 S4 Prestige | 6MT
laakness is offline   Reply With Quote
Old 09-11-2013, 12:06 PM   #4
MP4.2+6.0
Senior Member
Account #: 26081
Default But, per a good number of posts now...
and parts listing confirms there appears to be no difference in the suspension in the U.S. from the 3.0T (or others) to the SQ, other than the adjustment found w/ drive select. Are you sure its not just 20's or 21's vs a smaller size on the 3.0T, or the higher air pressures the SQ seems to be spec'ed with for the same size tires even w/out an underlying real difference in the suspension?
Current #1: '06 D3 A8L W12 brilliant black w/ amaretto; 4 seat setup, CPO; modestly lowered, H&R 20mm rear and 12mm front DRs with 275/35 on OEM polished + forged 20's; S8 sway bars (see: rear bar and gen'l D3 bar info and front bar); tweaked 385mm front factory brake mod and matching rear brake mod; matching C6 A6 back headrests (better rear view: headrest tweak); owner installed AMI retrofit with part number details here.
Current #2: 2013 Q5 2.0T hybrid; Scuba blue w/ chestnut sport interior; Euro delivery 7/2013 (pictured at Ingolstadt)
Prior (each modded): 2000 C5 A6 4.2 & '96 C4 A6 2.8Q, both still w/ family; '85 C3 5000S 5 sp FWD; '73 C1 100LS
helpful cross reference to a C6 post with MMI and other TSB's that also cover D3 A8's.
MP4.2+6.0 is offline   Reply With Quote
Old 09-12-2013, 08:48 AM   #5
Mister Spock
Account #: 259141
According to the Audi Sport 2014 brochure the SQ5 has a "tuned sport suspension". I don't doubt the statement from user MP4.2+6.0 that the parts are the same between SQ5 and Q5, since that's efficient German engineering. It's more likely that the SQ5 comes with the electronic suspension dampening is set for extra firm.
I do recall reports that the 2014 SQ5 would have a lowered ride height and shorter springs than stock, but I can find no proof of this in documentation online.
| 2014 SQ5 Prestige | Ibis White | Black & Silver Nappa | Beaufort Black/Aluminum Inlay | Supercharged Badges |
Old 09-12-2013, 09:04 AM   #6
MAMOHT
Account #: 264436
MAMOHT's Avatar
The brochure on the US site says "SQ5 sport calibrated suspension". Whatever that means.
MAMOHT is online now   Reply With Quote
Old 09-12-2013, 11:45 AM   #7
MP4.2+6.0
Senior Member
Account #: 26081
Default On preceding two posts, if you read thru boards in last few months...
you will find the conclusion in recent months that the US SQ5 got stiffed on any real changes here in the U.S. It apparently happened because it has to qualify in Audi's framework as a "small truck" to play the CAFE fuel economy games all the manufacturers do, to deal with various safety regulations that diverge between the two classes (Audi doesn't typically play this game; non Euro players often do), and to deal with some overlapping areas to the prior like bumper heights. Simplifying, among other things you need a minimum ride height (around 7 inches?) to fit in the category. Sport or similar suspension ride heights and/or ones for lower Cd's thus get the ax.
Hence apparently no revisions for U.S. bound SQ5's. As a trivia matter but suggesting the same issue, the Hybrid was supposed to sit lower too for Cd but that doesn't seem to have happened either. The parts #'s check backs these conclusions up generally. A few posts at the owner's manual and door jamb tire sticker level have revealed the SQ tire pressure settings are apparently meaningfully higher, but it's a bit unanswered as to why, or whether it was a typo or mistake. But if they are inflated a lot more, it will change ride feel, albeit anyone can do that with any Q5 based model.
Meanwhile, not surprisingly Audi marketing got ahead of the spec. They often just seem to duplicate the Euro copy (and often use Euro stock photos), but in cases like this it creates misinformation. I've seen it before on Audi performance models where some things folks expected to be there don't make the translation to the actual U.S. product they finally ship.
Old 09-13-2013, 05:43 AM   #8
acadianbob
Account #: 141694
I think what makes the difference is the lower profile tires. That's definitely going to make a difference on steering response.
acadianbob is offline   Reply With Quote
Old 09-13-2013, 06:50 AM   #9
PJQ5S
Account #: 164336
PJQ5S's Avatar
I was under the impression that, yes - indeed - ride height (and spring rates) are identical to other US spec Q5's (and don't get the 'Euro' treatment here in the US), but the SQ5 has different/stiffer dampers/shocks and thus qualifies the statement "SQ5 sport calibrated suspension". I feel like this has already been confirmed on the forum already...but I could be totally wrong (it's happened before...just ask my soon to be ex-wife! lol!)
"The Beatles were so high, they let RINGO sing a couple of tunes..." - Bill Hicks
PJQ5S is offline   Reply With Quote
Old 09-13-2013, 08:38 AM   #10
spijun
Account #: 184703
spijun's Avatar
Mistake
The difference between the of factory wheels 255/45R20 and 255/40R21 is only 1mm
Q5 2.0 TFSI,S-tronic,
Milano leather, B&O, 19" 5-arm polished
Excuse me for my English
spijun is offline   Reply With Quote
a6, audi, motorboating, qx70, sq5, suspension, versus
Forum Jump
