S Q5 rim size
Old 08-26-2013, 11:55 AM
Just Jordan's Avatar
Default S Q5 rim size
I have an S Q5 coming at the end of october but would like to start looking for Winter rims now. Does anyone know the offest I'm looking for on a 20'' rim?
Old 08-26-2013, 12:03 PM
larryV's Avatar
Stock specs are 21x8.5 +33 aor 20x8.5 +33.
You should be fine with any offset beyond +40 or so, but of course you'll always want confirmation from aftermarket retailers or do a test fit to make sure the spoke design clears the caliper regardless of offset.
Hartmann sells a variety of 20x9 +40 to +25 offset oem replicas that should fit, though the +25 offset might be too aggressive for some. They not only use stock ball-set lug bolts but also use oem audi center caps. I will likely go this route but will wait a few weeks before Hartmann can confirm SQ5 fitment.
Old 08-26-2013, 12:05 PM
Thanks Larry! A lot of great info.
Old 08-26-2013, 12:08 PM
spijun's Avatar
Search is your friend:
https://www.audiworld.com/forums/sho...2851996&page=2
Old 08-26-2013, 12:18 PM
AudiWorld Expert
Mark P's Avatar
I just added the SQ5 wheels to my little excel sheet - here you go for comparing the result of different widths and offsets:
(using the wheels I'll be getting on my car as a reference)
Old 08-26-2013, 10:10 PM
gtwagon941's Avatar
OEM RS4 wheels are 19x9 ET29. The brakes on the Rs4 are larger...any reason (looks aside) that a 19" wheel wouldn't work for snows?
Edit: from the thread linked to above:
19x7 ET 37 for winter tires
That will be my target.
Old 08-27-2013, 06:23 AM
spijun's Avatar
Very well done, still missing next:
Q5:
19X8 ET 27
For SQ5
Old 08-27-2013, 05:45 PM
Wunsch's Avatar
I have Hartmann 20" wheels with the +40 offset on my Q5. At that offset, they look natural and could easily pass for OEM fitment.
Old 08-27-2013, 06:14 PM
Never Follows
Audirings4's Avatar
OEM Rs4 wheels have a different center bore. No go.
Old 08-27-2013, 06:23 PM
AudiWorld Expert
Mark P's Avatar
Q5:
19X8 ET 27
For SQ5
Thanks - will add that.
Quick Reply: S Q5 rim size
