Microphone and voice assist not working in car I just bought
Hello everyone,
I recently bought a 2006 Audi A8 L and I'm trying to get it sorted out. Since I bought the car the voice assist button the steering wheel doesn't do anything. It says "button not active" or something like that. Also, more importantly, I'm having trouble with bluetooth calling. My phone (which is supported) connects to the vehicle via bluetooth. I can dial a number from the steering wheel and I can hear those I've called but they cannot hear me at all. It's as though the microphone is not working.
Notes: I tried updating the MMI software to the latest, which didn't help. I've also checked all the settings in VCDS for voice assist and telephone/microphone. Everything seems to be coded correctly.
In a search of the forums (I also read the entire Internet) I came across a threat in which an A8 owner spoke of having the dealership ignore the guidance to reprogram the car (VCDS?) for the Bose system, but there were no details that might be of use. Does anyone know what that could mean? Maybe there is some setting in VCDS I'm missing?
Any guidance will be much appreciated.
-Josh
-Josh
When I got my 07, the voice command was not working, but when the button was pressed, the voice said: "please say a command'. After replacing a lot of things (thankfully under warranty), a bad microphone was the problem. It's been fine ever since.
Hello everyone,
-Josh
-Josh
Hello, here are the complete VCDS scan results from this morning:
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Sunday,07,July,2013,09:22:07:04775
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 67 72 76 77
VIN: XYZ Mileage: 218600km/135831miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Sporadic communication error 1000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0E5767277
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E53EF56B905E268827
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 E HW: 09E 927 156 B
Component: AG6 09E 4,2L5V USA 0110
Revision: --H01--- Serial number: 0060873
Coding: 0000002
Shop #: WSC 19124 444 83960
VCID: 2541107AECF3A13073D
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 224B0B66FDDD560816F
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H07 0160
Revision: 01604507 Serial number: AUX3Z0E5767277
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8BFE98E6B014CD8B8B
Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 18
Mileage: 218016 km
Time Indication: 0
Date: 2013.07.05
Time: 07:05:38
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H01 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Shop #: WSC 00000 785 00200
VCID: 24470D7EE7C95838643
5 Faults Found:
01727 - Switch for Seat-Back Recline; Pass. Seat (E98); Back
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 4
Fault Frequency: 6
Reset counter: 16
Mileage: 218012 km
Time Indication: 0
Date: 2013.07.04
Time: 20:05:02
01724 - Switch for Seat Position; Pass. Seat (E64); Forward
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 16
Mileage: 218012 km
Time Indication: 0
Date: 2013.07.04
Time: 20:05:11
01728 - Switch for Seat Height Rear Pass. Seat (E66); Up
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 16
Mileage: 218012 km
Time Indication: 0
Date: 2013.07.04
Time: 21:02:32
00003 - Control Module
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 208
Mileage: 209880 km
Time Indication: 0
Date: 2013.01.07
Time: 18:13:23
01725 - Switch for Seat Position; Pass. Seat (E64); Back
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 16
Mileage: 218012 km
Time Indication: 0
Date: 2013.07.04
Time: 21:02:37
Note: I have coded out this TPMS - Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 346FQ057525740
Coding: 0000303
VCID: 326BFB26AD3DC688E6F
Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
1 Fault Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 231
Mileage: 217820 km
Time Indication: 0
Date: 2013.07.04
Time: 16:18:31
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000070356
Coding: 1052993
VCID: 1C37359EDFB960F8DC3
1 Fault Found:
01858 - Air Outlet Sensor; Right Center (G348)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 16
Reset counter: 16
Mileage: 217393 km
Time Indication: 0
Date: 2013.07.04
Time: 10:49:54
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 L HW: 4E1 955 113 B
Component: ILM Fahrer H12 0210
Coding: 0143123
VCID: 3169F42AA83BFD909F5
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7187452
Shop #: WSC 00000 000 00000
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 G HW: 4E0 035 593 C
Component: SDAR XM H04 0670
Revision: 00000000 Serial number: AUZ4Z7D7019634
VCID: 2B55E6428A179740A59
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0000N8O
Coding: 0532707
VCID: 2643177691F5AA287A7
Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 A HW: 4E0 953 549 B
Component: J0527 0310
Revision: 00H01000 Serial number: 90026050990070
Coding: 0012241
Component: E0221 H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 Q HW: 4E0 920 950 Q
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3E5000322
Coding: 0032203
Shop #: WSC 19502 444 10261
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H10 0080
Revision: 10 Serial number: 19003056068056
Coding: FCFE7BDC1B7904
Shop #: WSC 20205 444 52558
VCID: 275D1A7296FFB320411
1 Fault Found:
02230 - Digital Radio (DAB) (R147)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 218036 km
Time Indication: 0
Date: 2013.07.05
Time: 16:32:04
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 18
Mileage: 218016 km
Time Indication: 0
Date: 2013.07.05
Time: 07:05:38
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
VCID: 285F194E9BE1BC5848B
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H01 0010
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H44 1100
Revision: 00000000 Serial number: 355F/057548659
VCID: 387FC90E4B412CD8D8B
1 Fault Found:
02927 - DVD Read Error
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 4
Reset counter: 19
Mileage: 218505 km
Time Indication: 0
Date: 2013.07.05
Time: 22:27:06
Freeze Frame:
Hex Value: 0x51D8
Hex Value: 0x4E77
Hex Value: 0x0401
Hex Value: 0x0000
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H02 0090
Serial number: 00000512400004
Coding: 0003477
VCID: 1D31389AC4A369F02BD
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0090
Coding: 0032364
VCID: 204F016EF3D1441800B
1 Fault Found:
02126 - Central Locking Button; Exterior Door Handle
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 0
Reset counter: 19
Mileage: 218608 km
Time Indication: 0
Date: 2013.07.06
Time: 11:45:62
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040506250047
Coding: 0048702
Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Part No: 4E0 907 719
Component: Neigungssensor H04 0020
1 Fault Found:
02107 - Trunk or Luggage Compartment Opening Motor (V254)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 16
Mileage: 218025 km
Time Indication: 0
Date: 2013.07.04
Time: 22:53:54
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Revision: PROD_01 Serial number: 00000000016654
Coding: 0000016
VCID: 2A5BE34685ED8E485EF
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H09 0040
Revision: Serial number: 00000000063467
Coding: 0010111
VCID: 1E333F96C9A572E8327
Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0090
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
Shop #: WSC 19502 444 74592
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 C HW: 4F0 907 357 C
Component: AFS 1 H01 0030
Revision: 00000001 Serial number:
Coding: 0000018
Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396FQ057512118
Coding: 0000002
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0510
Revision: 00000000 Serial number: 00000000010959
Shop #: WSC 19400 444 84312
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 1506180008
Coding: 344530393135313035412056413031353036313830303038
Shop #: WSC 00000 128 00289
1 Fault Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 7
Fault Frequency: 1
Reset counter: 16
Mileage: 218025 km
Time Indication: 0
Date: 2013.07.05
Time: 05:23:14
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0090
Coding: 0032364
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000506220114
Shop #: WSC 12336 024 394758
VCID: 3467FD3E5729C8B8F43
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0090
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0020
Revision: 00H12000 Serial number: 08720515902405
Coding: 0201308
VCID: 23450E62E2C75F001D9
3 Faults Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 18
Mileage: 217440 km
Time Indication: 0
Date: 2013.07.04
Time: 11:29:07
01629 - Sensor for Parking-Aid; Front Left (G255)
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 7
Reset counter: 233
Mileage: 217440 km
Time Indication: 0
Date: 2013.07.04
Time: 11:29:07
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 233
Mileage: 218019 km
Time Indication: 0
Date: 2013.07.04
Time: 21:13:59
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H11 1130
Revision: 00000000 Serial number: 00000007503254
Coding: 0010970
End ---------------------------------------------------------------------
Chassis Type: 4E0
Coding: 0007773
Coding: 0000002
Coding: 0007597
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 18
Mileage: 218016 km
Time Indication: 0
Date: 2013.07.05
Time: 07:05:38
Coding: 4071520
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 16
Mileage: 218012 km
Time Indication: 0
Date: 2013.07.04
Time: 20:05:02
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 16
Mileage: 218012 km
Time Indication: 0
Date: 2013.07.04
Time: 20:05:11
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 16
Mileage: 218012 km
Time Indication: 0
Date: 2013.07.04
Time: 21:02:32
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 208
Mileage: 209880 km
Time Indication: 0
Date: 2013.01.07
Time: 18:13:23
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 16
Mileage: 218012 km
Time Indication: 0
Date: 2013.07.04
Time: 21:02:37
Coding: 0000303
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 231
Mileage: 217820 km
Time Indication: 0
Date: 2013.07.04
Time: 16:18:31
Coding: 1052993
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 16
Reset counter: 16
Mileage: 217393 km
Time Indication: 0
Date: 2013.07.04
Time: 10:49:54
Coding: 0143123
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Coding: 0532707
Coding: 0012241
Coding: 0032203
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 218036 km
Time Indication: 0
Date: 2013.07.05
Time: 16:32:04
Coding: 0410624
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 18
Mileage: 218016 km
Time Indication: 0
Date: 2013.07.05
Time: 07:05:38
Coding: 0015510
Coding: 4071530
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 19
Mileage: 218505 km
Time Indication: 0
Date: 2013.07.05
Time: 22:27:06
Freeze Frame:
Hex Value: 0x51D8
Hex Value: 0x4E77
Hex Value: 0x0401
Hex Value: 0x0000
Coding: 0003477
Coding: 0032364
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 19
Mileage: 218608 km
Time Indication: 0
Date: 2013.07.06
Time: 11:45:62
Coding: 0048702
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 16
Mileage: 218025 km
Time Indication: 0
Date: 2013.07.04
Time: 22:53:54
Coding: 0000016
Coding: 0010111
Coding: 0032364
Revision: --H03---
Coding: 0000532
Coding: 0000018
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 16
Mileage: 218025 km
Time Indication: 0
Date: 2013.07.05
Time: 05:23:14
Coding: 0032364
Coding: 0032364
Coding: 0201308
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 18
Mileage: 217440 km
Time Indication: 0
Date: 2013.07.04
Time: 11:29:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 233
Mileage: 217440 km
Time Indication: 0
Date: 2013.07.04
Time: 11:29:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 233
Mileage: 218019 km
Time Indication: 0
Date: 2013.07.04
Time: 21:13:59
Coding: 0010970
My suspicion is it's a combination of 07 and 77 coding.
Recent thread on it: https://www.audiworld.com/forums/sho....php?t=2802245
My 2005 had this coding:
You will need to reset the MMI after changing.
If it doesn't work, you can always change it back.
Code:
------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 731 H HW: 4E0 035 729 Component: Interfacebox H43 2740 Revision: 00000000 Serial number: 346AR057519329 Coding: 0000003 Shop #: WSC 05146 444 64369 VCID: 2649FCB4E861 Part No: 4E0 910 609 C Component: Bedienteil MMI H42 0100 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4F0 910 336 D HW: 4E0 862 335 Component: Handyvorb2 H10 0700 Revision: 00000000 Serial number: 00000007512824 Coding: 0010900 Shop #: WSC 02313 785 00200 VCID: 244DE6BC9E5D No fault code found.
Thank you so much! Changing the coding to the same settings as on your 2005 (above) worked like a charm. The microphone and the voice assist now work as designed. I really appreciate the help!
-JT
-JT
Perfect, glad to hear it JT !
Oddly been a lot of this coming up lately.
I'm no expert - I just think like a German, understand the coding logic, and drink a lot (1/2 German, 1/2 Irish )
-Jake
-Jake
lookaught::02_Avant!
A4 (B7 Platform) Discussion
04-13-2005 04:09 PM
