2003 audi a6 quattro 3.0l abs, traction control light
Old 05-30-2013, 04:54 PM
Jake Beason's Avatar
Default 2003 audi a6 quattro 3.0l abs, traction control light
I sent out the abs control module and was found to have no hardware issues so i took it down to a speciality european shop. he stated that I have a fault with my passenger side rear abs speed sensor and needs replaced.
1st. is this a easy fix if i buy the part, whats the part number so i know i purchased the right one, does it have to match the other 3 speed sensors brand.
2nd. He stated I need to replace my whole catylatic convertor due to a check engine light.
I have an OBD check engine light tool and this is what I got
p0421 Warm up Catalyst efficiency below threshold (bank 1)
p0456 Evaporative emmission system leak detected (very small leak)
Cal ID 8609095596 C15AA
3rd. He stated that I needed to replace my torque convertor in my transmission. Is this true as people I talk to say there is no way for him to diagnosis that without taking off the hoses and doing a pressure check, that his computer wouldnt be able to read a fault on that. Is he taking me for a ride?
Any suggestions about if i can complete these repairs my self as he quoted me 350 for the speed sensor 1250 for the catylatic convertor and 1400 for torque convertor labor and part.
Old 05-30-2013, 04:58 PM
And will this work to replace that sensor
2003 AUDI A6 QUATTRO New ABS Wheel Speed Sensor - REAR (Interchange numbers: 3B0927807C / 3B0927807B / 4B0927807 / 8E0927807) - CROSS CHECK PART NUMBER : Amazon.com : Automotive 2003 AUDI A6 QUATTRO New ABS Wheel Speed Sensor - REAR (Interchange numbers: 3B0927807C / 3B0927807B / 4B0927807 / 8E0927807) - CROSS CHECK PART NUMBER : Amazon.com : Automotive
Old 05-30-2013, 05:37 PM
Tech Guru
4Driver4's Avatar
Without VAG-COM, you're just guessing...although the fact that your car is an 03 3.0 does mean that it will need cats and a torque converter at some point.
prince13
05-25-2018 02:07 PM
Ruleski
07-26-2011 10:46 AM
Bart1
12-27-2005 09:55 AM
Bart1
12-26-2005 03:53 PM
Quick Reply: 2003 audi a6 quattro 3.0l abs, traction control light
