130,000 mile service
Old 05-09-2013, 02:05 PM
timindp's Avatar
Default 130,000 mile service
Anyone know what are the major components that are replaced or checked on the 130,000 mile service?
Old 05-09-2013, 05:54 PM
B5 Fanboy's Avatar
Timing belt, water pump, cam tensioners, valve cover gaskets, spark plug seals on valve cover, cam tensioner gaskets, spark plugs/wires, oil change, coolant change, power steering fluid change.
Old 05-09-2013, 06:58 PM
Jan_PL_S6's Avatar
Put the car on jack stands
Throw it in reverse
Put a rock on the accelerator
and wait.
Crisis averted.
Old 05-09-2013, 08:43 PM
MP4.2+6.0's Avatar
Default Sorry, but for OP this response is way off.
Start with the car has no conventional plug wires, so that didn't even apply to a D3 at all.
Many of the other things mentioned are common with the timing belt service, but that interval was back at 75K. To get on top of what needs to be done currently, you need to start with the car's history first. 130K miles would be between major intervals, if the last major one (105K miles as I remember on 4.2's) was actually done.
Old 05-09-2013, 09:25 PM
Jan_PL_S6's Avatar
Here's a quick page from the bentley manual showing the major service intervals and what should be checked/changed.
http://www.bentleypublishers.com/ima...ance.sched.pdf
Old 05-10-2013, 01:14 PM
timindp's Avatar
how do you reset the service light indicator?
Old 05-10-2013, 02:54 PM
MP4.2+6.0's Avatar
Default Need VAG-COM. Cannot be done...
via instrument cluster as on some older Audi's.
Old 05-10-2013, 06:29 PM
Brozee's Avatar
What I would do... Filters Plugs every 50-60k. All based upon what was done previously. I keep up on my maintenance and change things when they are actually needed.
Old 05-10-2013, 08:48 PM
s4master1's Avatar
Default crisis
Throw it in reverse
and wait.
Crisis averted.
2nd
chrisone
13
01-04-2015 08:05 AM
namjachoi
03-07-2011 04:16 AM
2002ss
10-01-2010 11:13 AM
übertek
14
07-25-2006 09:17 AM
Farb
06-12-2006 06:49 PM
Quick Reply: 130,000 mile service
