Brakes Discussion Discussion forum regarding brake tuning, upgrades and questions
TT MK2 Please help me with rear brake rotors
Old 01-27-2013, 06:52 PM
jh880428's Avatar
Default TT MK2 Please help me with rear brake rotors
I was working on the brakes. Front two were easy... but the rear ones are causing some headaches, and I was wondering if I could ask for some help.
Got everything off, pads, caliper.. but the rotor is stuck and I cannot seem to remove it without removing the caliper carrier. From previous experience, I did not have to remove the carrier but I cannot seem to get it off. And to get the carrier removed, I was not sure which tool to get. So I wanted to ask you for some help... Does anyone know how to do it?
I have some pictures to show what is happening here..
I think that is the 12 point screw or something. Or can I use Torx to remove the one between the spring? Does anyone know?
It gets caught like this
If you could please help me, I would really appreciate it!
Thanks,
Jae
Old 01-30-2013, 09:13 AM
Just Me's Avatar
I don't have a TT, but on every Audi i've ever owned, i have to remove the carrier to get the rotors off. Easy to take off, generally two bolts, some hex, some allen.
You also may need to tap it if it is rusted to the hub.
Finally, you need a piston tool that locks into the holes int eh piston, and applies (lots of) pressure while it turns the piston to screw it back in. Thee can be purchased from harbor freight in a kit that will handle pretty much any car.
Grant
Old 02-08-2013, 02:31 PM
Just Me's Avatar
Anyone there? Am i typing int he dark?
Old 02-12-2013, 07:51 AM
jh880428's Avatar
Grant,
THanks for the reply...
So you are correct, I had to remove the caliper carrier but I was not sure what tool to use. But I did end up finding it and it was triple square tool. More teeth then just regular hex.
Also, for my B7 A4, I did not have to move the carrier so that is why i tried it that way.
Thanks for your reply and I really appreciate your help!
Jae
Old 02-12-2013, 01:49 PM
Just Me's Avatar
glad it all worked out!
Triple square eh? They just keep adding stuff to keep us out i guess.
Grant
jh880428
TT (Mk2) Discussion
01-27-2013 06:51 PM
CartoonDog
TT (Mk1) Discussion
05-14-2005 05:58 PM
coasTTal
TT (Mk1) Discussion
04-02-2004 09:56 AM
Sloooo4esT
Audi Original "S" Cars
03-26-2004 03:24 PM
Quick Reply: TT MK2 Please help me with rear brake rotors
