2004 A8 hood stays open... latch broken?
my 2004 A8's hood wont close / lock down all the way on
the left side (looking from inside the car) so drivers side.
is latch broken that holds it all the way down?
where can i get one and how do i replace?
thank you
thank you
You'll need to use standard automotive troubleshooting techniques to determine that since we can't see your car. Could be the latch, could be the pin on the hood fell off, could be that the cable that controlls that suspect latch jammed in the pulled out position. To remove the latch I believ requires the "front clip" meaning front end with grill and bumper cover has to be removed. The Bentley service manual (on CDRom) details the procedure. Or the Elsa dealer searvice manual is even better. You should consider buying if you plan on servicing the car. If you are just flipping the car, well then you just may want to pay someone to repair it.
Trunk
My trunk does the same thing, but it's cold related. If you're in a cold area get it warmed up and try. Good luck.
-guy in a cold area who won't open his trunk below 50F.
i thought you meant the hood!
yeah, here in MN is COOOOOLD!!! and i put the car
in the garage, sprayed WD40 all over the non-working latch
raised it up about 10 inches, dropped the hood and VOILA!
it closed all the way.
thadeak
10-15-2006 07:33 AM
