S8 battery level in MMI
Old 09-12-2012, 10:49 AM
tx170754's Avatar
Default S8 battery level in MMI
Hello everybody,
Drove the, new to me, 2008 S8 from Baltimore to home, around 700 miles this weekend, what a car. I'm still getting us to it since it is different than the D3A8 that I still have ( for sale ) . One thing that I have realized is that there is no battery level in the MMI menu, I have searched in the archives since I remember that there were a lot of posts on the topic but I'm not able to find anyhting. Is there any way to enable this or should I go to the dealer and let them do it.
Thanks,
Dan
Old 09-12-2012, 10:52 AM
Brozee's Avatar
Connect VCDS
Select Control Module "07", Click on "Adaptation"
Select Adaptation Channel: 08
0-Hidden Menu Disabled
1-Hidden Menu Enabled
Enter value "1"
Click "Test", followed by "Save"
Close & reboot MMI by pressing "Tel" + "MMI Control ****" + "Upper Right Selection Button" (all together)
Press "Car+Setup" together until hidden menu appears, takes about 5 seconds
Then scroll down to Diag Settings and press enter
Then scroll down to Car Menus Maske (this is how it is spelt on the UK MMI) press enter
The find Battery Level and press enter
Scroll down the the bottom and press Accept Changes
Press the return button 3 tmes to return to the front screen
I had mine disappear after an MMI update, but never went back and re-enabled it, isn't a big deal at all for me.
Old 09-12-2012, 10:57 AM
tx170754's Avatar
Thanks,you're right I don't want to mess up with the hidden manus, I will probably ask the dealer to do at the first oil change.
Old 09-12-2012, 11:18 AM
pmdeaver's Avatar
Originally Posted by Brozee
Connect VCDS
Enter value "1"
Brozee, you rock! Is there any way I can convince you to move to NC? You're a great reference on this board!
Old 04-05-2013, 09:41 AM
Incaico's Avatar
Connect VCDS
Enter value "1"
Brozee,
After you close & reboot, should something happen? I did go into hidden menu and checked off box for battery level but where can I see it?
Old 04-05-2013, 10:58 AM
RenoRanes's Avatar
Originally Posted by Incaico
Brozee,
Press 'Car' then 'Systems' and scroll down to 'Battery Level'.
Old 04-05-2013, 11:23 AM
Incaico's Avatar
Got it. just couldn't reboot using the 3-finger salute. Had to use vag-com to reboot. There it was, just like u said.
Now I cannot go back to hidden menus...help?
EDIT:
Got it going. Just afraid I may break something...
Old 04-05-2013, 12:27 PM
RenoRanes's Avatar
EDIT:
To reboot without Vag-Com try pressing "Tel" + "MMI Control ****" + "Upper Right Selection Button" instead of "Setup" + "MMI Control ****" + "Upper Right Selection Button", for some reason the A8 reboot procedure is different to everything else.
Old 04-05-2013, 12:30 PM
Incaico's Avatar
So now I can get into hidden menu but when I get to the "CAR" setting, it is not responding.
I can go into the other settings but not "CAR".
Will reboot and try again.
Old 11-11-2013, 01:12 PM
1Wasserwerks's Avatar
I guess I'm late to this game. Got the hidden menu all figured out. Tried the enable battery level. Everything appears to have worked. Still no battery level.
Ugh. Reset several times with the 3 finger option, shut car down and restarted. No change.
Help?
Quick Reply: S8 battery level in MMI
