Can't shift into gear while engine running
Old 09-07-2012, 03:52 PM
Skewoooot's Avatar
Default Can't shift into gear while engine running
I just replaced the blown slave cylinder, bled the system, and now I can shift thru the gears while the motor is off, but not while on. When attempting 1st, the car will move forward just a tiny bit, and does the same backwards when trying to get it into reverse, but no grinding noises.
Did I most likely not bleed the system correctly, or has something else in the system failed? I used a vacuum bleeding kit on the slave cylinder bleed valve, and topped off the brake reservoir as needed, but the shop manual says they use an Audi tool that also applies pressure to the fluid at the top of the system in the reservoir.
I've checked both ends of the master cylinder and there's no signs of fluid leaking from it, but I'm not sure how they tend to mechanically fail.
Old 09-07-2012, 07:03 PM
David.Norton's Avatar
Clearly your clutch is dragging. I had one Audi that would drag and be very hard to shift, but didn't grind, so similar to yours. Friend of mine forced it into gear passing uphill on a mountain road, blew the clutch up. Never saw a clutch before or since in so many pieces. Anyway, it could still be your hydraulics, but I have also seen debris on the clutch shaft cause them to drag, the driven disk needs to float off of the flywheel for the clutch to disengage, and if something is in the way preventing that then it is going to drag.
Old 09-08-2012, 11:48 AM
Skewoooot's Avatar
Yikes. Really hoping that's not the case, but thanks for the feedback.
Old 09-11-2012, 08:33 AM
Former Vendor
ALLDATAdiy INFO's Avatar
Alldatadiy.com has various repair information that may help with your clutch issue. Good Luck!
RDBBJD1
03-17-2015 10:53 AM
Harowing
06-14-2008 01:04 PM
newports4
09-08-2006 12:22 PM
JPRobertsons
06-15-2006 09:28 AM
Afroney
12-01-2002 07:19 AM
Quick Reply: Can't shift into gear while engine running
