07 Q7 sunroof frame/drain leak?
I'm not sure what the deal is with all of the leaky sunroof posts that have been brought up lately, but our 07 Q7 is at the dealer now with an amp that quit working due to a leak.
They say its because of a leaky sunroof frame and want $2800 to replace the frame, plus another $1300 for the Amp. Is this right?
Are the frames to blame or is it really just a clogged sunroof drain?
Can anyone tell me where the actual drain is, so that I can check it out. Also, where exactly is the Amp located so I can check out how bad the leak is?
Any other info would be great too.
VIN # WA1BY74L77D043665
Thanks
Thanks
Thanks
Thanks
The Bose amp is in the back (trunk); the posts were brought up by me for other Q7 drivers with the same issue to see what is going on. My dealer changed one by one the front drains and later Prestige in Miami did replace the rear ones after a leak that damaged the amp (you can read my post that I also brought up). There is a TSB, look at the TSB post from justforfun. This is a current issue for some of us, and is a design problem that Audi corrected after 2007. Get as much information from thess posts, tell your dealer about it and call Audi NA. To tell you the truth you should be entitled to a 100% covered repair from Audi NA, you will have to negotiate, it will take you a little fight.
Good luck
Not sure for the cost of the frame, but for the amplifier, here in Canada they asked $1,200 CDN which I believe would be approx. $1,300 US.
I have the same issue, lost the amplifier due to a leak on my 2007 Q7.
I having the same problem with my car as we speak. Its at the dealer now. Luckily, the extended warranty i purchased with my vehicle 2008 Audi Q7 did cover the Amplifier but i still have to pay for fixing the leaky sunroof which was like $300 which by the way is not my fault. The dealer told me that i have to even change the Battery as it is going to die on me. But i am going to wait for it to die as it will cost me $700 more to get a battery at the dealer.
I was a big fan of Audi before .. and i have even owned an A4 before.. but i am now starting to think...
Exactly my thoughts. Ideally i would want Audi to cover the issue. They should have done a recall and fixed the issue in the first place. But, i think at least i was lucky that i took a warranty.
Amazing...
Yep- I would wager most if not all 07 Q7's with S/R's will have this issue. It sounds like some 08's as well. I wonder if the newer ones will also suffer the same fate over time.
Audi
2007 Audi Q7 4.2 premium
As you can see many of the 2007 Q7 owners have dealed with this problem, that Audi knew short after the Q7 came out. AudiNA/Audi instead of recalling them, they issued a TSB and did not inform dealers or customers. Many of us believe that this is unacceptable and Audi should step up and offer a fix when the symptoms (water leak)and damage (electrical component damage)show up, it does not matter that the cars are out of warranty, when they find out the issue and came out with the TSB, "all of the Q7" on the road where under warranty.
