| A4 (B5 Platform) Discussion Discussion forum for the B5 Audi A4 produced from 1995-2001 B5 FAQ |
#1 | ||
1999 Audi QuattroJoin Date: Jun 2005
#2 |
More information --- I have found the term "limp mode" in regards to the transmission, and that there are lots of causes for that, including air flow issues. Before all this I was getting codes for the O2 sensors (although they look fine when monitoring with VAG-COM(. The car was never used hard before we got it --- I found the air intake basket (before the filter) full of junk, and cleaned that and installed a KN filter. Cleaned the MAF sensor, no codes on that, but why not. Tried to clean the throttle body, did spray the sensor, but did not get the throttle body off to clean. The vacuum tubes in that area were all brittle and I replaced them. Since this and the tranny fluid replacement we have only driven 30-40 miles. No codes have come up so far, but the clunking and limp mode have happened again.
#3 |
2005 Audi AllroadJoin Date: Aug 2004
Is there any play of the driveshaft?
#4 |
No play in the driveshaft; this only occurs once every few days, very randomly, but always while at a constant speed.
#5 |
Geoffrey Bove 1999 Audi A4 Avant Quattro 1998 Audi A4 Avant Quattro (crunched in rear end and in yard as parts car!) 1997 Ford F150 plain jane 1991 Bridges Point 24 w/ 12 hp Westerbeke Diesel(=Iron Mainsail) 1988 Kubota 2850 w/ 34hp Diesel |
#6 |
OK, now it threw some codes at me:
16795 - Secondary Air Injection System P0411 - 35-10 - Incorrect Flow Detected - Intermittent 16806 - Main Catalyst; Bank 1 P0422 - 35-00 - Efficiency Below Threshold 16816 - Main Catalyst; Bank 2 P0432 - 35-00 - Efficiency Below Threshold 16487 - Mass Air Flow Sensor (G70) P0103 - 35-10 - Signal too High - Intermittent 18032 - MIL Request Signal Active (Check TCM for errors too!) P1624 - 35-10 - - Intermittent 17549 - Load Calculation Cross Check P1141 - 35-00 - Implausible Value 17535 - Fuel Trim; Bank 1 (Mult) P1127 - 35-10 - System too Rich - Intermittent 17537 - Fuel Trim; Bank 2 (Mult) P1129 - 35-10 - System too Rich - Intermittent As I said, I just cleaned the MAF --- could the KN be doing this?
#7 |
Ah, you shouldn't have touched the MAF.
In any case, how are your engine mounts? Someone had a clunk from differential mount as well. |
#8 |
Thanks GTA --- the air flow codes were there from the beginning, although not so many (see second of my initial posts). Everything said "clean MAF." Now I will do it again and replace the K&N as well, I think it threw some oil in the mix. The symptoms are not consistent with engine mounts, it is far more irregular, duration is variable, and sometimes there are multiple shimmies. I would do the sound if this was CarTalk but cannot ---- it more feels like the tranny is going to simply fail, like it goes out of and then back into gear. As one other person on this Forum said, feels like the next sound is going to be that of the tranny falling off the car and onto the road!
#9 |
Sounds like your Tranny is in safe mode, i bought my 98 A4 in December and it was in safe mode, the guy told me that one of the tranny mounts need to be changed, come to find out it was locked out. when i have the car in auto mode i.e. "D" it goes into safe mode, if i over ride in tip mode its fine but i have a recognition switch error code come up and tranny goes back into safe mode. I changed out the tiptronic shift board and the tcm and nothing fixed it.
| Tags |
| 1998, a4, active, article, audi, codes, dashboard, fault, mil, p0411, p0422, p1141, powered, request, shemale, signal, video |
