| A4 (B5 Platform) Discussion Discussion forum for the B5 Audi A4 produced from 1995-2001 B5 FAQ |
#1 | ||
1996 Audi A4Join Date: Feb 2010
#2 |
2005 Audi AllroadJoin Date: Aug 2004
If your turn ignition "on" without starting the car, does everything seem to work? Like climate control, instrument cluster lights up, etc...
#3 | |
I'm worried that it's something like the engine seizing up. Are there any relays or fuses going to the starter that might be bad? How would I test the starter itself? |
#4 |
If you can clip a positive end of a jumper cable on the positive starter stud then clip the other end to the positive side of your battery. Then attach one end of the negative lead to your battery and touch a convenient ground on the engine with the other negative end. If the starter engages and the motor turns over, the problem is somewhere else. You'll also know if seizing is the issue though I doubt after such a short time the engine would be seized. Good luck.
#5 |
one other note - you might want to check the driver's side pillar drain to see if that's clogged. Maybe water entered through the clutch master firewall seal if the water got that high. Just a thought. I had a 1996 Passat wagon with 10 miles on it fresh from the dealer. Left it in my driveway the first weekend and went to visit the folks in another state. Monday morning I found 2" of water on the floor right behind the driver's side. No where else. Took it back the dealership three more times over the next couple of years with the same water intrusion problem. It was very intermittent. They never solved it and I turned the car in after the lease was up. Very frustrating.
#6 |
one final note - you didn't mention if your car was manual or auto. If manual, make sure it's out of gear before you test the starter. My friends dad crushed his knee against the garage door when he forgot to take a mustang out of gear before jumping the starter. Be safe.
#7 |
#8 |
I'm wondering if the clutch sensor might have gotten shorted out by the water. Does anyone know what fuse that's on or where to find the sensor?
I mean that would explain everything else electrical working but turning the key doing nothing. If the water was coming through the clutch master firewall seal, it might have damaged it. How does that apparatus work? Is there any way to bypass it? |
#9 | |
2001 Audi TTJoin Date: May 2002
Check ignition switch, they have a high failure rate with several recals.
2001 180 TTQ coupe 1976 Triumph Spitfire 2008 A4Q 2.0T (sold) 2003 A4Q 1.8T (sold) 1996 A4Q (sold) |
#10 |
I replaced one of these already about 3 years ago. It was an aftermarket replacement. I can't remember how I tested it the first time, though. How do you figure out whether the ignition switch is the problem?
| Tags |
| 18t, 1996, a4, audi, awhile, clcking, engine, key, sitting, start, time, tt, turn, turns, won |
