Old 05-09-2012, 03:14 PM   #21
AudiFX
Originally Posted by audiqv8 View Post
How the hell did they bent the valves when they were working at the rearend of the engine? All timing is done at the front end. You neeed for them to explain to you how they manage to bend the valves. I would have them tow the car to an Audi Shop where they can pull the Codes. My guess is that they screw up either the speed or crank sensors which is causing the engine not to start (no spark). Is the cylinder compression low?
Response/timing slipped/skipped somehow when they were trying to align the TC. They attempted to start car and it ran for 20 seconds then died......that is where damage was done.
AudiFX is offline   Reply With Quote
Old 05-09-2012, 05:28 PM   #22
4Driver4
Tech Guru
4Driver4's Avatar
Originally Posted by AudiFX View Post
Response/Because car was sitting for weeks in their yard, they think that some hydraulic lever slipped and threw off the timing. They tried to start engine and noticed the damage was being done.
Bold faced lie. No question.
4Driver4
Growing old is mandatory; growing up is optional.
1980 VW Scirocco (mid-life crisis car)
1983 Mazda RX-7 (revolutionary sports car)
2003 Mini Cooper S (just because)
1995 Mazda Miata, Superdupercharged(anti-Audi)
1999 Mazda Miata SSB (track beotch, no plate)
2003 GMC Yukon Denali XL (the anti-earth)
2004 Dodge Dakota (hey, at least it's stick and 4x4)
Old 05-09-2012, 05:29 PM   #23
4Driver4
Tech Guru
4Driver4's Avatar
Closer to the truth. The more I read, the more I am convinced that they tried to turn the engine over using one of the cams instead of the crank.
4Driver4
Old 05-09-2012, 05:37 PM   #24
GTA_Driver
2005 Audi Allroad
GTA_Driver's Avatar
I'm just going to reiterate - get another shop, a qualified Audi shop, to rebuild the engine.
The timing on my 93 Quattro 100 went, a shop repaired the engine at a steep price, a year later the head gasket went.
Get your A6 out of there.
GTA_Driver is online now   Reply With Quote
Old 05-09-2012, 07:10 PM   #25
audiqv8
When things goes wrong it seem to pour. What happens when a shop is totally clueless, read the links below.
http://forums.audiworld.com/showthread.php?t=2183340
http://forums.audiworld.com/showthread.php?t=2183458
http://forums.audiworld.com/showthread.php?t=2183496
http://forums.audiworld.com/showthread.php?p=19012304
My suggestion would be to get a second opinion before these clowns do any more damage to your car. Since they can't tell you how the timing slipped, then I would question if the timing did slipped.
audiqv8 is offline   Reply With Quote
Old 05-10-2012, 02:58 AM   #26
4Driver4
Tech Guru
4Driver4's Avatar
I'll reiterate as well:
Rebuilding just opens a can of worms. Repair the damaged valves only.
But I agree that the car should be anywhere but Aamco.
Who takes an Audi to Aamco anyway?
4Driver4
Old 05-10-2012, 10:13 AM   #27
GTA_Driver
2005 Audi Allroad
GTA_Driver's Avatar
I meant rebuild In the sense of repairing the damage.
Semantics?
Old 05-10-2012, 12:17 PM   #28
4Driver4
Tech Guru
4Driver4's Avatar
Semantics?
Maybe to some. But they are two vastly different thing in my world.
I my guess is correct, there are a handfull of bent valves on one of the two banks, probably bank one. I bet only one head needs to come off and less than a dozen valves replaced.
4Driver4
Old 05-10-2012, 06:46 PM   #29
GTA_Driver
2005 Audi Allroad
GTA_Driver's Avatar
you didn't know which one I meant?
Old 05-11-2012, 02:55 AM   #30
4Driver4
Tech Guru
4Driver4's Avatar
It was not clear to me, and it may not have been clear to the OP.
Why not just say what you mean?
4Driver4
2001, 2002, 2003, 42, a6, audi, audiworld, crank, dont, read, rebuild, sensor, start, transmission, vagcom
